General how to prepare the Grenadier for very poor Diesel fuel quality?
1:09 PM
Bamberg
I need some advice in order to prepare my EU spec Diesel Grenadier MY23 for a long overland journey through some countries were somewhat bad Diesel fuel quality is available only.
What I know so far, in some countries (Kenya, NAM, SA) the Diesel is already equipped with an additional Diesel water separator filter from the factory, also without AdBlue and I guess some other parts are different to an EU specced Diesel. I also expect that the engine control software is different as well for those countries. The additional Diesel water separator filter can now be ordered as an option from MY24 on, but I assume we can retrofit this part at an INEOS workshop.
Maybe someone have deeper knowledge what we can do/change so that the Diesel engine can work with those bad quality fuels.
Having the fuel/water separator is the most useful step. Your main enemies are water, particulates (often rust) and algae contamination (including algae do do).
ADDITIVES
Another thing I do is use Fuel Doctors in remote areas, but I do not know if you can source it. It is added to every tank when I am remote (in Australia, where you can get dodgy fuel).
Sometimes I will use Smith Lubricants Diesel Power Up instead, neither is cheap, but it is cheap insurance. I do not use both at once, unless the fuel is being stored in my aux tanks before going into the car.
MR FUNNEL
Mr Funnel can filter out water and debris from fuel, look here. It is the cheapest option over the longer term.
All AU Spec diesels have the water/fuel separator as standard, even the 23 year model.
View: https://youtu.be/ik0VNBHcnMw
Having the fuel/water separator is the most useful step. Your main enemies are water, particulates (often rust) and algae contamination.
ADDITIVES
MR FUNNEL
Thanks, Mr. Funnel filter is already on my list. This part is great to clean any fuel from water and debris before you fill it into your Jerry Can or tank!
Yes, also handy when the fuel is provided from an awkward receptacle:
Did you manage to retrofit the water separator filter in the end ?
I would look at Dr Funnell linked above.
Hi Doc,
Regarding fuel filters, has anyone found a way to properly prime the filters if changing without a dealer? I learnt from a tech that grenadiers prime of cranking so unless you have a diagnostics tool it’s virtually impossible to prime properly.
Hi Doc,
I do not have any knowledge on that topic, and I cannot remember it being posted either. However my memory since the accident is not very good - one reason I maintain the list of links.
Hi @Dieter Only just spotted this thread and as I remember euro spec Grenadiers can accept up-to 50ppm sulphur in diesel so diesel quality in Southern African is fine for EU spec Grenadiers. South Africa, Botswana and Namibia, 50ppm diesel widely available, can’t remember fuel quality in Angola but I’m sure diesel of 50ppm is available in Malawi and Zambia when I was there last year even though mine is a petrol Grenadier. Things are changing fast in Africa as more and more euro spec cars with modern diesel engines are being used there and so fuel quality has had to improve to supply demand. I’m pretty sure you’ll be fine in all those East African countries. South Africa and parts of Namibia even has 10pm diesel
And of course carry the “MrFunnel” for any fuel not taken from a forecourt. I use one for petrol also. 👍🏼
Define poor quality. Different things require different measures.
AWo
If that is a question for me then I’m talking about sulphur levels. Everything else you can filter out I think. When I lived in Malawi I had a common rail diesel engine in my Hilux and never had any problems travelling around different countries, even though some were very high sulphur at the time.
During a trip through west Africa in 2019 I had a euro 5 spec 2014 Defender 2.2 diesel and had green sludge dripping out of my exhaust due to extremely high sulphur in Guinea and Senegal. That probably wouldn’t do the injectors a lot of good.
That’s the best photo from sulphur in fuel I’ve got after it had all dried up after an exhaust re gen. The other thing to note is that the exhaust required many more regents than normal and consequently more oil changes.
