We are in agreement but it is aggravating at the very least. I should have kept my Land Cruiser 200 as the reliable, never have to think about it rig.Don't panic my friend!
We "self select" in terms of reporting "failures" on this enthusiasts' forum... while extremely helpful in understanding what "might" go wrong, there's also a need to put such reports into context in terms of a statistical probability. I'd venture to say that by my "back of the envelope" estimate the vehicle is far more reliable than many other marques.... (a million V8 engines in the recent GM recall, Honda and Hyundai likewise with the curse of manufacturing debris left in engine blocks)...
(Yes, my HP coolant reservoir also developed a crack...it's a BMW issue across many models).... but I'm relaxed about the Grenadier's overall reliability![]()
Any update from AlliSport on aluminum expansion tanks?Hi folks, I also had a failure at the seam weld on my High Temp tank right off the showroom floor. Had it replaced under warranty, and then the water pump started weeping, likely due to improper coolant bleeding procedure.
That all said, I've been quite motivated to fix the classic BMW plastics issue on the engine as I accrue miles on my Grenny. I've been referencing BMW and Toyota A90 GR Supra owners/enthusiasts and learned a mountain of info that's quite helpful and reassuring that the problems can be managed over time.
Regarding, the coolant tanks: I'm currently talking to AlliSport in the UK, they've been in the business of Land Rover and similar fluid tanks for quite some time and have been upgrading plastic reservoirs with their proven aluminum tanks.
I'll keep folks updated as the project progresses. Currently I have Qty: 2 OEM Ineos coolant tanks (Hi & Low temp, respectively) on their way to them to conduct R&D on aluminum replacements.
They're also working on a slight update to the ZF plastic power steering reservoir that won't leak or have a split failure mode (similar unit)
Andrew is still working on these and they're modeling & prototyping the quick disconnect fittings last I heard in an update from them about 2 weeks ago.Any update from AlliSport on aluminum expansion tanks?
Agile Offroad is reportedly also working on at least the Hi-Temp coolant tank as well.
I have a 15 year old E90 and given how much of the Grenadier seems to be adapted from BMW directly or the companies who make BMW parts, I can tell you i have experienced the exact same issues with the E90 expansion tanks ever since I moved from NYC to Texas.Before tackling a long trip I checked my fluid levels and noticed that the coolant in the HT Coolant Reservoir looked low. The HT Coolant Reservoir is number 1 with the blue cap in the pic below from @Rok_Dr's excellent guide:
With the engine running, I noticed green coolant dripping from multiple locations around the middle seam of the HT Coolant Reservoir - not good. Here's a screen grab from a video I took showing one drip location:
My dealer is Regal Ineos in Roswell, GA, and, after I brought my vehicle in, they confirmed it could not be repaired and needed to be replaced. It took approximately four weeks for the new HT reservoir to arrive after they placed the order. After it arrived, Regal installed it in short order, under warranty, and all appears good to go now.
My speculative theory on the seam failure is that whatever sealant was used between the two halves of the reservoir was not well suited for the hot and humid summer weather in Alabama, which is what I also blame for the rubber door seal delamination I experienced.
We'll see how the seam in the replacement tank holds up in August. Hopefully, they are using a better sealant these days. It's too bad they did not design the reservoir in one piece rather than pressing two plastic pieces together.
Through this process (and thanks again to Rok_Dr.'s guide!), I learned that Valvoline's Zerex HT-12 Coolant (I bought it at O'Reilly Auto Parts) is what I needed to refill my HT reservoir so I could still take my trip.
Hopefully, my reservoir's failure was a one-off, but it's worth taking a look at yours the next time you are under the hood. I did not notice a puddle under my vehicle, and it only seemed to start leaking with the vehicle running. Regal said they had not had other reports of this type of failure.
Common look to the plastic tanks, send a picture to your dealer and get replaced. If long distance ask to post and return the faulty one if you are DIY person. Not sure they will go for that idea but some of you are 100's miles from your dealer.
I am surprised the aftermarket has not yet stepped up to offer aluminum replacement tanks for both the high temp and low temp circuits. I will be replacing mine as soon as they do.
Gotta keep these aftermarket small businesses up and running.More surprised IA would not want to stop the bleeding on 100% failure rate item.
Ahh, like how GM is making one transmission upgrade company fabulously rich?Gotta keep these aftermarket small businesses up and running.![]()
