Heating system is useless
I’m glad you’ve got your new order in.
I don’t think there is anything wrong with the batteries as supplied. I think the issue is when they are allowed to go flat especially if that happens a few times. Most batteries apart from Lithium will quickly be destroyed if completely flattened. Maybe your Grenadier was parked up along time before delivery or since and not had the batteries maintained?
If it is a lead-acid battery, doesn't matter if it is wet or AGM, small currents are killing them as well. That is due to the growth of crystals while power is taken out. High currents lead to small, fine crystals, low current (like ECU, smartphone loading, etc.) lead to large crystals.
These crystals are material which can not be used for power and they block the flow of current. When you charge the battery. the small and fine crystals are reverted very well. It is difficult to revert the large crystals. They may never go away and thereby you loose electrical active material, reducing the battery capacity and power thereby.
Another effect is, that when taking power from a battery both plate materials (lead and lead oxide) is turned into lead sulfate (which is reverted to lead and lead oxide while charging). That leads to physical stress in the plates and small parts can break apart, also reducing power and capacity. That an donly that is addressed by AGM. It keeps these parts in place, so they do not fall down and are lost for the capacity.
AWo
AWo
Thanks. Although I’ve read all about this stuff most of it goes straight over my head to be fair. That’s why I’m not a mechanic or technician.
Moll marketing blurb seems to think their AFB batteries are AGM in disguise 🤔. I know we don’t have AFB. but some form of enhanced EFB called EFB PLUS especially made for Ineos. There’s nothing to be found about EFB PLUS batteries from Moll
Reactions: CRH
EFB means there is a labyrinth inside the battery lid to prevent water from evaporating. Because evaporated water needs to run a long way to leave the battery through the ventilation, it has time to condensate and flow back again instead leaving the battery. That keeps it working for an extended period of time.
That has nothing to do with AGM. AGM means that the acid is bound into glass fibre mats between the lead and lead oxide plates stabilizing them and thereby making them somewhat more resilient to low currents. But low current is not what lead-acid batteries (wet, AGM or gel) are intended for.
AWo
Lynn told us they removed the aux battery for several reasons, including that the supplier is no longer making a part (ctek 120 I believe). If IA were to replace that part with another, the truck would need recertification/homologation which would be stupidly expensive for a system that that the aftermarket has provided better options.
I have 1 unused in box if anyone is interested?(CTEK 120)
So the average owner is much better off without the factory option and putting in a much more versatile option
I would say the average user does not need a second battery. What IA did was reduce/remove the need for people to carry a jump start pack.
Almost everyone who wants a second ( or third! ) battery - to use as an independent power source from the main starter battery... Didn't get anything they wanted and must go after market.
So, strongly agree that the after market provided the solution. IA solved a problem that only a few people may have had.
Just an update on this...
The car has come back from its service and recalls. The problem with the heating was the pressure tank that other people have mentioned. The mechanic noticed the pressure tank had been leaking. He has repressurised the tank and the heater is working again but he has ordered a new pressure tank from Belgium which will take about 4 weeks to arrive in NZ. Now the temporary fix is in place, the heater works well, after about a 5 minute warm up period.
It's great to be back driving the Grenadier without misgivings. The misbehaving heater had been the only thing that was truly irritating me.
Mine has at least 60c in the back and virtually nothing in the front
Was that the same
Did they fix it
Was that the same
Did they fix it
Bleed the system many times. Make sure both expansion tanks are topped up to max.
Try turning aircon off. Try shutting rear vents. It's certainly not perfect but will help
