Smart alternators are controlled by an ECU to limit charging to a range as a part of emissions optimization
not HVAC but HAVOC system is what they deliveredSeriously they should be embarrassed enough to fix this for all existing owners. What they have produced is an hvac system from a high school automotive class project. It’s pure ass
If it is a lead-acid battery, doesn't matter if it is wet or AGM, small currents are killing them as well. That is due to the growth of crystals while power is taken out. High currents lead to small, fine crystals, low current (like ECU, smartphone loading, etc.) lead to large crystals.I’m glad you’ve got your new order in.
I don’t think there is anything wrong with the batteries as supplied. I think the issue is when they are allowed to go flat especially if that happens a few times. Most batteries apart from Lithium will quickly be destroyed if completely flattened. Maybe your Grenadier was parked up along time before delivery or since and not had the batteries maintained?
Thanks. Although I’ve read all about this stuff most of it goes straight over my head to be fair. That’s why I’m not a mechanic or technician.If it is a lead-acid battery, doesn't matter if it is wet or AGM, small currents are killing them as well. That is due to the growth of crystals while power is taken out. High currents lead to small, fine crystals, low current (like ECU, smartphone loading, etc.) lead to large crystals.
These crystals are material which can not be used for power and they block the flow of current. When you charge the battery. the small and fine crystals are reverted very well. It is difficult to revert the large crystals. They may never go away and thereby you loose electrical active material, reducing the battery capacity and power thereby.
Another effect is, that when taking power from a battery both plate materials (lead and lead oxide) is turned into lead sulfate (which is reverted to lead and lead oxide while charging). That leads to physical stress in the plates and small parts can break apart, also reducing power and capacity. That an donly that is addressed by AGM. It keeps these parts in place, so they do not fall down and are lost for the capacity.
AWo
Most stuff on here is for me, I just use it to tell the dealer what needs doing or ideas for adding to the vehicle. All very helpful but I'm no mechanic.Thanks. Way over my head.
I have 1 unused in box if anyone is interested?(CTEK 120)Lynn told us they removed the aux battery for several reasons, including that the supplier is no longer making a part (ctek 120 I believe). If IA were to replace that part with another, the truck would need recertification/homologation which would be stupidly expensive for a system that that the aftermarket has provided better options.
No, you needed the CTEK 250 SE for a solar MPPT.Did the Ctec 120 have solar input?
So the average owner is much better off without the factory option and putting in a much more versatile optionNo, you needed the CTEK 250 SE for a solar MPPT.
