Gutters surviving 420kg?
das mo
2:23 PM
Just talked to BSI again. They created a high lift version of their feet that might fit my setup as additional support and take it to 5 feet each side. A, B and C being the gutter mounted DOT200 and the red marks being the spot for the BSI high lift mounts connecting to the bars.
Tom109
8:23 AM
DaveB, so the three SUP boards basically created a sail that the gutters could not hold against the bow wave from the truck? Scary stuff! I've also not been impressed by the flex we've seen in the gutters.
As I mentioned before, I've used roof racks on a Range Rover Classic (aluminum gutter), Discovery 1 (Steel gutter) and Series (alu/steel gutter) - all of which could be considered flimsy - with no gutter failures. I expect the Grenadier to be more substantial or at least equivalent. I have had rack feet fail, most notably from carrying a 17-foot canoe where lateral loading and wind resistance can be very large.
10:23 PM
I've had illegal loads on roof bars of my Disco 1 with not a hint of flex.
Almost 30 years of use , not damage at all.
Tom109
8:23 AM
When my boys were young and we'd go to a LR Rally the Disco seriously looked loaded like the Camel Trophy!
Loc Nar
7:23 AM
Alabama, USA
Are the Grenadier gutters aluminum, steel, or a combo?
Tom D
1:23 PM
I think the issue is that the Grenadier gutters are really wide. any system that mounts right out on the edge of the gutter is going to stress it, like Thule. Something mounted closer in should be fine.
Pat-Ard
Global Grenadier #00520
2:23 PM
Hi, @das mo ,
will those feet be sold seperatly and be compatibla to the aluminium profiles?
ADVAW8S
Global Grenadier 0044
5:23 AM
Kirkland, WA, USA
On le tech set up, it looks like you can get you hand onto the lashing bars. I wonder if you put let's say you put Black Sheep molle panels first and then rack, it would work.
ADVAW8S
5:23 AM
Kirkland, WA, USA
Also, here is idea if you like Letech or Black Sheep, you attach a bar with some space on to the L track. Just spit balling hear.
bigleonski
10:23 PM
Brisbane QLD, Australia
I wonder if you had any grab rail damage issues using the BSI rack as it is anchored whether IA would cover under warranty- not likely. Can anyone remember the load allowance on those rails? Was it 150kg?
10:23 PM
I was trying to find it but no luck
From memory DCPU posted the drawings and submission to the patents office about a year ago.
I recall they can be used to tie down the full roof load of 150kg dynamic and 420kg static but can't find it written anywhere.
DenisM
10:23 PM
I'm sceptical that the grab rail solution by BSI is within the design intent of the IG...
IIRC the grab rail was designed for a tie down, not as a weight bearing entity.
From the IA brochure descriptions, the roof load of 450kg static and 150kg dynamic was implied to be shared between the roof itself (on the roof strips) and the specialised gutter mount design where the weight is distributed .
Loc Nar
7:23 AM
Alabama, USA
Does the full length roof rack rest on the roof strips? The brochure says the max static/dynamic ratings stated are achievable with it on (minus the weight of the roof rack of course).
grenadierboy
10:23 PM
Armadale Australia
Denis - that can't be right otherwise the load would have to be spread across/held by BOTH rubber strips and gutters to achieve static & dynamic weight limits if not then you would need to deduct the weight limit for either one each was NOT carrying any weight?
My old G wagen gutters had no flex at all and carried plenty of weight - they must be steel
