Do you happen to know the dimensions of this nut? The diameter at the bottom of the washer and the wrench size?I sheared off two bolts on the diff end when my shaft unlived itself. Double nutted and grips got them out.
Was it perhaps an M26 x 1.5?
Unfortunately I did not measure. Second driveshaft now on.Do you happen to know the dimensions of this nut? The diameter at the bottom of the washer and the wrench size?
Was it perhaps an M26 x 1.5?View attachment 7919152
When new CV bolts go back in, should they be thread locked, or anti seize?
never ask a human to help with menial tasksIn other news, this son of a bitch sucks at holding a flashlight. View attachment 7919164
What is more impressive is the typing skills of the dog.never ask a human to help with menial tasks
Ratchet strap and hitting with a punch/hammer got it loose. Thank you. But I had to drop the crossmember to get the leverage I needed.I put in the FB comment about using the ratchet strap, and yes, sometimes it takes a couple whacks with a small deadblow hammer once you have tension on the strap. As Dokatd commented, the strap goes around the transition on the driveshaft, not the CV. I broke one bolt on the pinion end, on my second replacement (#6 currently installed). The bolt that broke was an Ineos replacement, which has a red/purple colored threadlocker. I now remove the factory threadlocker from new bolts with a wire wheel and use blue threadlocker instead. Waiting on word on another prototype shaft that is under development before I pull the lift or drop down to the 1.7.
Skip to 2:40Hey @Dokatd I’ve made big progress but holy heck now getting the CV off is proving to be a task too. C clip is out and I can’t get it to budge. Beating the hell out of it! Any pointers?
Some have to be pressed off, some fall off. If you know someone with a press that's the easiest option to be sure. Otherwise any independent auto shop should be able to press it or a machine shop. I can probably get you into a shop in Boulder if that's not to far.Hey @Dokatd I’ve made big progress but holy heck now getting the CV off is proving to be a task too. C clip is out and I can’t get it to budge. Beating the hell out of it! Any pointers?
Yep. Watched that too and still nada….
The press is likely what’s going to be needed. I’m about 30 mins from Boulder. What’s the shop’s name?Some have to be pressed off, some fall off. If you know someone with a press that's the easiest option to be sure. Otherwise any independent auto shop should be able to press it or a machine shop. I can probably get you into a shop in Boulder if that's not to far.
how 'bout a cutoff wheel on a grinder, 180 degrees out?Yep. Watched that too and still nada….
My next brightest idea is flipping the Grenadier around and using my winch with the driveshaft ratchet strapped to my Quartermaster’s recovery point to separate it. What could go wrong?
There are probably more simpler ways though.
I have a feeling all of these issues that I’ve run into have a lot to do with the heat that is in that joint. So many fused pieces.
PM sentThe press is likely what’s going to be needed. I’m about 30 mins from Boulder. What’s the shop’s name?
