Front Drive Shaft Update
RTI does not account for weight, tires size or ground clearance. RTI is based on height a tire can be lifted without others lifting and then adjusted for wheel base. You could literally start with your vehicles frame on the ground and no tires and still get a relevant RTI or CTI score.
You can also achieve high RTI with zero compression or even zero extension. You can achieve a high RTI with a rigid from suspension and a slinky rear.
RTI/CTI scores are only a tiny fraction of what tells you if a truck is good Offroad.
The examples you give are extreme cases that would never be applicable to production vehicles. In actual production cars that can be purchased by consumers a rig with a higher RTI score is very likely to be better off road than one with a very low RTI score. It is by no means the only vaild metric but it certainly serves as a way to identify the relative capability of OEM vehicles. Otherwise we would all be driving lifted Subarus and Audis. That said there is very much a point of diminishing returns and anything above 700 is not likely helpful to the typical off road driver under normal driving scenarios. There is also an inverse relationship between increasing RTI score and on road handling and stability. So a very high RTI score can make a vehicle completely unsuitable for high speed highway travel, if not outright dangerous. None the less, it is a valid way to compare the relative off road performance of stock OEM cars.
I'd argue front to rear balance is more important, and agree that retained springs are better than dislocating ones in the real world. IMO, CTI is far better at showing the front rear balance in articulation..
I did specifically call out front rear balance as an important metric in a prior post. I just find it misleading to say that RTI/CTI is meaningless for production rigs. It is a valid way to compare relative capability. It is almost universally agreed upon that Jeep Wranglers are the most capable off road vehicles currently for sale not including things like Unimogs. They also have the highest RTI/CTI score in factory form.
Well you kinda changed the goal posts a bit. But I'd still argue that Jeeps high RTI scores are coincidental or at least predictable. Naturally a production vehicle made to offroad at the level of a stock jeep is going to have a high if not the highest RTI. As well it's one of few that still have solid axles. But the high RTI does not make it a superior vehicle Offroad. I believe the Range Rover classic used to have one of the highest RTI's of stock production vehicles.
But attrition of off-roaders and jeeps having the highest production RTI does not make the numbers more valuable than they really are. Take away the lockers and a Jeeps RTI is utterly pointless. A less vehicle with lockers will go far further down the trail.
Anyways, I don't think we are really in disagreement after your subsequent posts, but you just didn't care for my direct frank statement.
I did not change the goal post. We can agree to disagree. I like a good debate.
Fair enough, but adding in "Production Vehicles" changed the goal posts a little bit. That becomes very limiting these days. We just don't build production vehicles like we used to. So again the best production Offroad vehicle becomes predictable in 2026 but not because of RTI. A locked CJ2A would spank an unlocked Wrangler. Have you seen how stiff CJ2A's are?
Not sure why we would be talking about anything other than production vehicles on a forum dedicated to a production vehicle. And just about any locked vehicle will spank an unlocked vehicle assuming equal ground clearance, tire size etc. But lockers are a feature and discussion separate from the value of RTI scores. All things considered I would prefer to keep my tires on the ground as much as possible, using lockers infrequently as terrain demands, as doing so puts more stress on the drive line especially up front.
I'm older, old-school Rover-guy and just like to know the wheel travel at each corner. I was always a fan of retained springs too.
How about how much pressure is applied as one wheel rises and the other is pushed down. The more the better right?
I get the articulation pinching the boots. I was up at Warner this week while traveling and they have noticed on a sampling that boot failures may also have an extended high speed highway (+80mph) component. Maybe a contributor as well? I know @Texas Grenadier has a lead foot ;-)
I think this is a sampling bias. Warner is in Salt Lake. That part of the country has long stretches of 80 mph speed limits and lots of 5+ hour drives to places like Moab. As a result you have owners wheeling AND long fast drives. It’s the full extension from wheeling that is causing the problem. the high speed is simply a correlation not a causation.
No doubt a heavy foot !!!! I’m a firm believer in high speed accelerating causing the failure rate of the CV joint coupled with the shocks topping out at higher speeds. I replaced two joints on my own vehicle as well as one last weekend on the trails while we were at the Palo Duro Canyon. I do quite a bit of highway driving as well. I get about 5000 miles before I start noticing a rip boot.
Without boot pinching the boots would handle highway speeds reasonably well. But the pinching compromises the boot and failure comes quickly with heat and high RPM.
