Front Drive Shaft Update
So that's why non-lifted Grennys are ok, but when you use the more frequently off-road the higher CV angle due to off-roading causes more wear. Makes sense. Just wish there was a way to fix this without having to deal with the vibrations of a propshaft like the one Agile has. This vehicle is meant to be used off-road, not a pavement queen.
Off-roading is not the only cause for stock Grennys to fail. If you tow a heavy load, drive over big whoops on the highway on a daily basis or hit speed bumps etc faster than most. Anything that causes you to reach the extent of the suspensions travel even momentarily will lead to failure. It's cumulative damage that eventually gets you.
