Front Drive Shaft Update
So that's why non-lifted Grennys are ok, but when you use the more frequently off-road the higher CV angle due to off-roading causes more wear. Makes sense. Just wish there was a way to fix this without having to deal with the vibrations of a propshaft like the one Agile has. This vehicle is meant to be used off-road, not a pavement queen.
Off-roading is not the only cause for stock Grennys to fail. If you tow a heavy load, drive over big whoops on the highway on a daily basis or hit speed bumps etc faster than most. Anything that causes you to reach the extent of the suspensions travel even momentarily will lead to failure. It's cumulative damage that eventually gets you.
Mine isn’t lifted and the boot tear was discovered at 34k miles.
I have OEM boots and Terra boots. I have cut cross sections of both. They all fail the same way. They thin out at the pinch, show evidence of light surface on surface friction and of course a tear/crack. The thinned out area directly correlates to how far in or out the boots collar is placed on the shaft.
The evidence I have collected is not up for debate as far as I am concerned. We can all have opinions, but I have hard evidence over many joints to prove my theory out. If you want to fix the problem today without voiding warranty then you need to install limit straps that reduce overall travel of the front end by maybe 1-2". I bet you can get over 100k mi with that setup. But you're neutering the truck at that point.
So the “pinch” in your opinion is just a fold that increases friction on the interior surface?
More or less. The bellows doubles over and squishes just a bit. Just enough to cause the boot to heat up and eventually "extrude" itself. The area extruded gets super thin and finally can't hold up to the centrifugal forces.
You mean up on the top side or where, exactly? I haven’t been able to get my hands on mine - stopped by the dealer yesterday to get a bunch of fly fishing stuff out of the back but it was pretty torn up because they’re dealing with a few issues. Hopefully I can get a look at it this week if they get all the parts in and if Ineos can give them some clear guidance.
