Turning radius improvement with simple bolt-stop mod?
Stock steering damper? Could you post your steering readout in Degrees L/R, before & after this steering stop mod?
Fox steering damper. Not the fancy one. I had 29 and 31 degrees before the change and haven't moved it yet. I'll update in the next day or two.
Since you are discussing steering stabilizers...
Does anyone have any experience with the basic Fox stabilizer vs the Fox 2 ATS.
The roads were I live have lots of damage from earth movement. This exasperates any off center issues.
I use the 18" wheels with a more street type tire as well as the basic Fox steering stabilizer for long highway travel.
I have 17" wheels and AT tires when overlanding or off road.
The question is: does anyone have experience that would show a marked improvement with the advance Fox 2 ATS.
Thanks
I climbed under mine today to adjust the stops to the "2- thick washer" method. BTW- they're M12 bolts, so you can always use 12mm washers too, instead of the 7/16" Agile calls for. (I find it odd that people in the US will install SAE parts on a metric car.) Anyway, the stop bolts on my Gren are 40mm. They seem to be bottoming out before they reach the washers. I cleaned the paint off with a wire brush. I ran the stop nuts all the way down to be sure the threads were good. I double checked and it's not because I'm reaching the end of the threads on the bolt (i.e. the washers are thick enough.) So I ended up with the stop nuts adjusted all the way in and called it a day. If I need more- I suppose I'll investigate more.
"Thick" metric washers are not common here even in industrial settings, while every corner hardware store has Grade 8 SAE hardware readily available.
Obviously, but for four (4) M12 washers while every car hobbiest, farm kid, or hardware store has SAE freedom unit washers within reach in minutes?
I just walked over to the hardware store and looked in the stainless metric section. Bought 4. Ace hardware for the win.
You found 4 "thick" stainless washers at Ace? 🤔that doesn't happen most places.
Out of curiosity I went looking for the equivalent metric washers at McMaster they are 25 for $14 and another $36 for shipping, So $50.
The question was was why John used SAE washers Grade 8 washers, it's because it is what we have on hand.
I'm within an hour drive of McMaster, so overnight shipping is by their white van delivery, and typically only $8.
McMaster is my go to source for anything I cannot get at my local hardware store. If they don't have it you probably don't need it.
I would also recommend BelMetric. They are exceptional and a small business. They support automotive and my favorite, Unimogs. Though they are not a vehicle parts supplier.
I put in the washers today. Initial reading is still 32 L/R. In reverse I get 34 L/R when I slowly roll and keep the wheel pinned. 🤷‍♂️
I adjusted my stops. Power assist steering gets to 32 deg each side. I didn't check the non-assisted limits before but with the stops adjusted to the bottom of the OEM bolt+nut and Fox ATS 2.0 stabilizer I get 37 deg left and off scale right, which is in excess of 40 degrees.
Actually, I found 4 thick stainless 12mm washers and 4 thick stainless 10mm washers. Sometimes it's a crap shoot as to what's in stock (they're vendor stocked bins) and surprisingly, they had no 7/16" grade 8 washers. I bought two sizes because I didn't know what size the bolt was and wanted to have on hand whatever I needed. 7/16 converts to *almost* 12mm, so there was the possibility it was an M10 bolt. It's a great video- and great information- it just left a question that I solved on my own.
For the record, I can see that I've added a bit of turning angle by running the nut to the end of the threads on the bolt. However, there appears to be no power steering input at those angles and I can't tell if the limit is the Fox steering stabilizer or the stops. I'm running the Fox stabilizer (not ATS) sold by Agile.
This is with basic Fox stabilizer and stop bolts with original lock nuts bottomed. With original settings it was 32/32 and had to use some force to get the last couple of degrees. Now it is considerably lighter all the way to the hard stop. Almost g-wagon agile now.
Which wheel angle is BTW shown on the display? Front of course, but always left or always right or always inner or always outer ... ?
It has been a few months and seems to have settled in. Power steering takes both sides to 37 degrees. Left goes to 40 and right goes a bit past 40.
