Incorrect, mine was a Teraflex, that helps nothing. Only the Agile shaft will help.7500, about 1000 after the 30mm lift.
I’m going to try the Teraflex boot. Folks I know using them aren’t having issues.
Running a single-cardan 1350 driveshaft is a band-aid which comes with compromises of its own.Incorrect, mine was a Teraflex, that helps nothing. Only the Agile shaft will help.
Hopefully it’s a 200 and not a 250, as the T24A’s are having failures akin to the V35A’sBut then again, maybe I’ll just buy a Land Cruiser and not have to worry about this ever again.
I don’t think anyone will accuse you of this being how unlikely it is. Give yourself a 2.5” lift, and put an accordion boot over the entire assembly while switching to a teraflex and see what happens. It’ll be a sample size of one, but…
But... if the cause is a stone... it will not hide anything, because it's not happening. How else ya gonna prove this without 2000 people putting boots on?A big boot might hide any early signs of failure like spattered grease but it doesn't seem that there's much advance warning anyway. The boot tears, the grease is flung out, and you're DOA in a couple of klicks.
Well, that all depends on which LC... theres a 600 mile 2003 100 series on cars and bids. I beat the living shit out of my 2002 and only retired it for rust. Operationally flawless, and super bland to look at. Ive had every LC (no prados) gwagon, and few various weirdo rigs, and that 100.... for the non hard core the category I put the Gren into, that rig still seems like the closest to the sweet spot a decade after parking it. I'm on week 12 total of this thing being in the shop since I bought it. It's front end flaws appear to un-correctable. I may be bidding. Dump this and fill my man crisis void with a 997 gts.New Landcruiser has a few...concerns;
1. Junk Engines
2. Gearing
3. Transmissions
4. Under engineered diffs
5. Delicate front end
Pick your poison, but at least Ineos tried to develop something robust we can easily upgrade. The new Toyotas not so much.
The gentleman that did that said it did not work out.Hello everyone,
here's a picture of my drive shaft where I replaced the CV joint and additionally installed a boot that shouldn't tear anymore. The boot is filled with grease and should prevent the CV joint from running dry.![]()
I wonder if this worked out? Even if it wasn't filled with grease it would make a good dust boot.
