Front Drive Shaft Update
mine doesn't. is yours "Yeah, I'm a back door man"?
Younger generation know...but they just don't understand.
Where's the Howlin' emoji when I need it? Not trying to Muddy the Waters 😉
Epic design failure…
Good thing is I caught this one super early. It's full failed, but I could see the initial failure a bit better since it just tore open. I am very much thinking the boots outer shell is too close. I believe the boot itself might be able to handle the angle, but it's seems some unique position of the axle will allow the shaft to pinch the boot. This is probably exacerbated by running the max caster spec and beyond.
I am going to likely order two new joints and experiment with one of the boot housings.
Thank you for your attention to this matter. Hopefully you can make this point of failure great again.
If not, you'll probably just caster aside and buy a bulletproof Tacoma.
I won't drive a Yota. At least not for long. I like rebuilding them and flipping them but that's about it.
