Fender / checker plate question
I’ve have the Bison ones, I posted a while ago. They look great. I have them stuck on so far so good but there is a risk of the 3m tape delaminating in the centre due to rain water. The fenders warps in the centre with heat and cold. My advice is to prep the panel with alcohol spray they provide. Once stuck down, place something heavy in the centre of the plate overnight. Finally thin black silicone around edges to prevent dust and water. It will hold, never come off yet but if you want to be 100% sure, then rivet. I may give this a try in future.
I couldn’t do without them now. I often sit on my front bumper and rest my brew on the fender plates or camping lantern.
Quite, very useful area. Quite liked the ones another forum member fitted which curve over the front towards the headlights.
Hi there. The ones from Bison Gear in Poland look good for gluing;
Well, I all envy you guys, but unfortunately Aluminum (metal) are not allowed here due to safety, so hence my quest for plastic ones (like on new Land Rovers).
I did find rubber material (with diamond-shape motive) with I might cut to size, but not sure it will 'stick' to the car with 3M glue.
So no 'non-metallic' fenders out there yet ?
It will stick with 3m but it might warp or shrink with the sunshine.
well, rubber is rather cheap, so could replace 'regularly' or am I too optimistic? Weather (mostly) not extreme here...although a bit less wet than Manchester :)
High density polyethylene (HDPE) stabilised for UV exposure and fixed with nutsert fasteners might be a viable alternative. Not sure about thickness required.
Problem is the thinnest plate of HDPE I found is half an inch (12.7mm). I just ordered Black Diamond Checker Plate Matting in EDPM rubber (UV and Ozon proof) from the UK (3mm), will let you know once it arrives how it looks like.
There are aluminium or powdercoat checker plate panels available in the UK fitted with 3m VHB tape or drilled and riveted
The checkers retail for $330 if purchased separately and the installation charge at my dealer is $490, making the total cost installed at $820. Each checker is fastened with eight rivets and there are installation instructions on the UK INEOS website.
It would be your choice to install them yourself.
I have not attempted to stand on them...
I'm sorry if this has been addressed already given long thread, but is the actual fender plastic or is it steel? I want these, but only if I'm not drilling into a steel panel.
Also for those who've run the OEM checker plates for a while, do you notice any rusting of the rivets?
Looks great. Gracias!
FWIW I didn't want to drill so I went with the GP factor adhesive ones and couldn't be happier. They've been on over a year with no issues whatsoever. They won't be as grippy as the diamond pattern type but work well and IMO look better.
I had the same fear and I was assured they’re aluminum fenders. I also asked for black rivets. The silver ones stand out too much; I’m not a fan of the silver on black.
Love all the nerdy detail talk. 😍
I’m going with OEM because I like the cross hatch design and I actually like the old school industrial looking silver rivets.
I absolutely don’t want to drill holes if I don’t have to, but alas that’s the deciding factor. I want to make sure the fender is aluminum and not steel. There’s no way I’m drilling if steel.
It’s aluminum, and it isn’t like you’re taking them off. Drill the holes and be done with it. Just be deliberate. Measure twice, drill once.
I mean, You either have a snorkel, or you have patches for a snorkel.
Bison in Poland make some good aluminium ones. Stuck on with 3M tape and black siliconed around the edges. Can rivet if you wish. Rivet is better but mine are stuck on and so far, after 2 years all is ok. Reason why I say rivet is better is because water will get behind hence why I siliconed. I plugged the pre drilled rivet holes with plastic caps.
Pros and cons of both ways but these are good quality and cheaper than OE.
Looks great, mate!
I'm just going to have the dealer install the OEM ones with rivets while it's stuck there getting the HVAC "fixed". I live in Los Angeles so don't really have to worry about rust. Just being my normal OCD self.
Thanks for shariing!
