No all by memory from just taking notice the last week, but I did edit in the dripping LH footwell - due likely to AC condensate!!! I had forgot that was so late typing! I come from a world where 'QA' is paramount (i.e. what a$$holes say!) and so just recall things generally in order as they appear or happen.Wow!
At first glance, your review seemed dauntingly long: I was worried that you had fallen prey to logorrhea.
Very good review, thank you.
How were you able to remember all the objects? Did you use a voice recorder?
Settings question. You can chose what to show in the so called INFO1-2-3-4 parts of the display.
Congrats for the car - and for the review.![]()
@archerwolf no problems at all my friend. Just my opinion, but I would think a sub 6' and 90kg person would fit. I am 5'10 and 70kg and fit between the seats easily. Except my broard shoulders...Your first impressions are probably the only one I’ve read that has mentioned baby seats in the back. I appreciate the insight! If you are able to tell, how much space would there be between the baby seats if you installed two baby seats in the back? Would there be enough space for an adult between the two baby seats?
Thanks,
I'll do an edit soon on what I will have dealer deal with. The obvious items are WATER INGRESS, Front of Right sensor issue, LH footwell (AC likely) condensate drip. But I'll go in a BOLD ADD to the end of the - off to dealer issues (need to make a coffee first!).Comprehensive! Thanks @trobex
Out of all of the above, would be good to know which/any items that you’re looking to get the dealer to rectify? For example isn't there is a fix for the wet feet/ door seals?
- approx. VIN? (therefore build date)
- latest software?
… these things are helpful as we all track the state of the art
Cheers
On mine (minor hijack!) they all work as intended - best I can tell and AA works very well - no lag with AA that I can tell.. North reads as north! DAB radio is the major setback - it is bad. Sound level from speakers is excellent.Do absolutely all your head unit functions work? eg attitude screen , compass if you have one , odometer , android auto (if you have it?)
Water Ingress - personally I think it's wonderful that Ineos has designed this feature in, to make those of us nostalgic for their Old Defenders feel right at homeI'll do an edit soon on what I will have dealer deal with. The obvious items are WATER INGRESS, Front of Right sensor issue, LH footwell (AC likely) condensate drip.
Known issue in Oz.DAB radio is the major setback - it is bad. Sound level from speakers is excellent.
Also in the Motherland of DAB, Deutschland.Known issue in Oz.
The question is , why is it offset?Reversing Camera - the off-center alignment is pretty average and tow bar line up is frustrating with this set up.
Bad design, completely weird!The question is , why is it offset?
Maybe an afterthought.Bad design, completely weird!
My first instinct is to say that it is offset because of the different sized rear doors, but...The question is , why is it offset?
Doesn't bother me , but anyway in advance of my new van I've ordered the Gator grv92mkt , very good price if you shop around. Will wire it up to the Gren and in due course the van.
I don't want any dash/windscreen mounted unit as the windscreen is very small to start with.
P.S. I have not read anywhere of a quiet voice phone issue fix.
It's not the best to line a trailer up and even 20mm off centre is shyte - especially when the trailer is up at 2.1T and pulling that over in the grass is a PITA. Comparing to the 200 series launched in 2007 probably highlights how wrong the design is! But it is what it is and people need to be aware is a fair way of centre and night nights in reverse flare the picture badly.I don’t see why this is such a mystery? Isn’t the camera centred with the spare wheel? So obviously some style guru at Ineos decided it would look better there rather than cockeyed to the left of the door AND tyre but centre of the actual car, where the people who actually use the thing would prefer it to be and dang the style police.
As mentioned above, the 200 Series is also offset, and I manage to use the camera to line up trailers/vans just fine so I doubt the IG will be any different.
Nay can't move it. Just have to guess to nearest 10mm when sitting the ball!Maybe an afterthought.
Can it not be moved , or is something underneath in the way?
I don't know, that's one of the things I didn't dismount yetMaybe an afterthought.
1. Blanking grommetI don't know, that's one of the things I didn't dismount yet
But if you move it, you have hole in the original position that you should fill up.
Or leave it there, and instal another one ?1. Blanking grommet
2. A cork
3. Duct tape
4. (For the win) weld and paint.
5. Install the Gator unit with it's own cam
