Canopy, Flat tray, Truck Caps for the Quartermaster
Here are some pictures of the Dirtbox tray, some tweaks and order books will be open. I have asked if they could color match the half canopy doors and the under tray doors plus the side boards.
I called Couch off-road to learn more about the tray and spoke with Jay Couch. He spent 30 mins giving me the low down. He is more than excited about the outcome and I am on the Dirtbox train. I wish I had a transcript of our call as every second he gave such good info.
Off of memory.
The size: he has extended the tray to over 6 feet in length and width is same size as width to door handles.
20 gallon water tank
Spare tire is mount under the bed with a slide/box to hold it. It opens
19/20 gallon spare gas tank with ability to fit another 19 gallons by head rack.
The frame sits on a sub frame 3 point sub frame. The reasoning is the QM chassis is very stiff. He wanted to minimize flex between the flat tray and bed.
Rear winch mount, his test winch is 13k
With the added weight he is going with 1000 springs.
Here are some pictures of subframe, the spare tire hatch, rear winch
He has my attention for the spare tire location alone
For a utility body, I wouldn't have guessed color matching would be something I'd pay for, but after looking at the norweld rigs, the tray/cannopy without them look sloppy and unprofessional. textured coatings are sold as durable, but in reality, they are for shops that can't paint.
Outside of the dirt box product, are any of the Australian trays available?
Norweld can be shipped here, Grenx is finalizing their tray with a debut at end of this month. I spoke with UTEMaster but no distribution here for tray.
Norweld gets a lot of attention due to the YouTube videos. I have seen there products installed at Mule Outfitters and the quality was top shelf. However, Mule no longer uses their product and they went to MITS instead. If there is another importer/shop for Norweld in the USA I would really like to know.
ARB has bought MITS so currently it is up in the air if and when we will see their tray system offered in the US.
Bowen said they would love to build a a tray/canopy for the Quartermaster but I don’t know if they had a chance to scan and build one yet.
Looks like DirtBox will be the first. Shame they can’t offer a paint option. Although you could always get it wrapped afterwards.
A company out of Hungary called XLW is developing a quartermaster cap as well as other parts like rock sliders for the quartermaster.
I had a quick chat and quote with David from XLW, the hungarian company behind the canopy mentioned by Rocky.
It is a very nice proposal below 4k$/€, with load bars rated around 90kg dynamic.
Canopy weight + roof bars add approx 92kg to the truck which is reasonable.
I am tempted :)
Laurent
I am tempted :)
Laurent
That is very attractive proposal. I'm still leaning towards flat tray half canopy set up.
This thread will be a list of available aftermarket solutions for the back of the QM. As more information becomes available, the thread will be updated.
Truck Caps
Trays/Canopy
Hi,
Gearmate have just launched a Canopy for the Grenadier Quartermaster. It is a 3mm Aluminium Canopy that is fabricated, so not modular and doesnt need assembling. They are a UK company that manufacture everything in house.
the link is here: https://www.gearmate.co.uk/product/quartermaster-hardtop-canopy-solid-gullwings-copy
Hi,
This is looking good as well, with an aggressive price tag. I like the little extra height and the massive load rating.
It’s a good thing there are more and more options for QM owners.
Worth checking if local fitting charges are less than customs fees.
MajorB
Nice looking set up, I like the spare tyre location and rear winch set up. The tray looks a bit flat pack like a lot of alloy trays available in Australia. I didn't think the QM had that much chassis flex to need a heavy 3 point mounting system like an expedition truck.
When I spoke with Jay, he mentioned you could order it without the subframe. But it's only 1200 for the subframe. I need to learn more about sub frame but I wonder with bigger springs, how much your gvm goes up?
Spare tyre location would be affected with the AdBlue tank that sits in that space on the diesels. Looks good though, and would match my
Donney Grey QM
He mentioned being able to put a 19 gallon tank in the head rack. That might be a solution to add tank. Then a custom def tank where he was talking about a spare tank between the wheel and frame. When I talked to Jay, he mentioned he has to move the petrol evaporator tank where the spare goes anyways.
He mentioned being able to bit a 19 gallon tank in the head rack. That might be a solution to add tank. Then a custom def tank where he was talking about a spare tank between the wheel and frame. When I talked to Jay, he mentioned he has to move the petrol evaporator tank where the spare goes anyways.
There might be room behind the exhaust. Just remembered that the AdBlue tank is above the exhaust muffler. Extends down to the bottom of the cross member or around 100mm.
I also talked to Jay and he mentioned that he is shooting for a target max weight of 8000 lbs with canopy and gear installed. I believe he is running the Eibach Pro Line HD springs, plus 250 lb. front and 1000lb. rear.
BTW… Those are 35x10.5R17 Kenda Klever MT2’s on the stock wheels with 35 mm spacers. I’m not sure how a wider tire package would still work with under tray spare tire system.
