Can one leave the engine cover off safely?
If I remember rightly, it is just noise suppression and aesthetics. I have to dig back many years into my memory and it's not at it's best anymore
Spot on, the insulation is for sound and the cover is for visual appeal. I replaced mine with a '24 BMW engine cover and removed the insulation when I swapped the air filter for improved air flow the unintended benefit is hearing the turbo spool up.
Thinking back, wife had a base speck car that didn't have the engine cover but the higher spec ones did. Obviously poor people are older and have impaired hearing so there is no need to suppress noise quite so much.
And then you get the carbon fibre engine covers for people who...... 🤔
  • Mind Blown
Reactions: CRH
The cover is likely sound deadening as dictated by some technical EU regulation or other. I seem to recall a similar discussion on a Land River forum after the TD5’s (or was it the 2.4 Puma?) were introduced years ago.
Could be, but could also be to maintain the temp of the engine for as long as possible after turning the engine off, which reduces cold starts (if you drive yours as much as I drive mine -- WHAT?!? We're out of SALT? What crime is this?!? I'll be back in an hour!).
  • Haha
Reactions: CRH
