Brown Davis or Long Range Automotive?
Yeah I’d like to pick a spare up as well. I’m also leaning towards heat shielding that polymer bracket…
I’m not sure also how much heat is transferred through the metal exhaust hanger to the rubber/polymer link between exhaust and chassis mount.
You’ll find the exhaust really makes a loud drone once you have the exhaust mods to accommodate the tank. I would like a quieter solution.
I’ve just watched a utube video from Mainline overland in the USA and took a screen shot of the fuel pump used for the LRA auxiliary petrol tank.
Update -
After dissecting the packaging for our LRA auxiliary fuel tank - ordered with the upgraded fuel transfer pump:
The rotary vane inline fuel pump appears to be a Carter P4070.
I'm having the LRA Aux tank installed right now but with the standard pump. Living here in AZ 115 degree summer I'll be testing the transfer speed for sure!.
Additional heat shielding was applied during our LRA Auxiliary tank install.
Does anyone else have theirs hitting their I think its a control arm on the rear axle??? My rear muffler swings back and forth so much it makes contact?
On my truck the clearance dent on the exhaust pipe still contacted the rear suspension bolt on certain driveway entrances; the fix would have been to make the clearance dent in the pipe a bit larger
I'm thinking of having a custom exhaust ran, not a fan of the slapping while going over decent size bumps and obstacles.....
Do you have a picture of the exhaust part in question. I have the LRA auxiliary petrol tank, along with the associated exhaust modification. I’ve not noticed any noise or contacting of metal parts.
On a separate note. I don’t particularly like the exhaust sound with the modification, so went to a specialist exhaust workshop to see what they could do , to change /quieten the exhaust note. After having a good look and taking measurements underneath they concluded they couldn’t do much, that would make much difference as space is too tight underneath to accommodate a larger or further silencer.
Yeah let me work on getting some pics, I actually want to go the opposite, basically take all the cans out... lol I'm actually wondering if they can even get the rear exhaust out now without dropping the fuel tank??
So the first pic is the Kings shock it will hit that but it take quiet a bit to move it that far and has to be a side to side motion. The other pics is the rear axle control arm bolt always touching it, looking around I see no way to move the exhaust toward the rear to put space there. It also moves around a lot due to the rubber exhaust hanger connections. No way to remove the exhaust without dropping that tank.
I’ve just read the installation instructions. Is this the same bolt ?
