Brown Davis or Long Range Automotive?
Yeah I’d like to pick a spare up as well. I’m also leaning towards heat shielding that polymer bracket…
I’m not sure also how much heat is transferred through the metal exhaust hanger to the rubber/polymer link between exhaust and chassis mount.
You’ll find the exhaust really makes a loud drone once you have the exhaust mods to accommodate the tank. I would like a quieter solution.
I’ve just watched a utube video from Mainline overland in the USA and took a screen shot of the fuel pump used for the LRA auxiliary petrol tank.
Update -
After dissecting the packaging for our LRA auxiliary fuel tank - ordered with the upgraded fuel transfer pump:
The rotary vane inline fuel pump appears to be a Carter P4070.
Additional heat shielding was applied during our LRA Auxiliary tank install.
Does anyone else have theirs hitting their I think its a control arm on the rear axle??? My rear muffler swings back and forth so much it makes contact?
On my truck the clearance dent on the exhaust pipe still contacted the rear suspension bolt on certain driveway entrances; the fix would have been to make the clearance dent in the pipe a bit larger
