Bison Gear Ineos
@Bison-Gear, what is the status of the design of the left cargo basket for those of us with Grenadiers with the inverter option? It's been over six months since this issue was identified. Are there still any plans for that or has design of that basket been abandoned? Thanks.
Basket is ready but we're looking locally for Grenadier with inverter to test it (here it's not that common feature).
Maybe you can find a volunteer through this forum. If local sourcing does not work out, I'm sure someone with an inverter equipped vehicle would be willing to receive and test a prototype through mail and provide feedback with detailed measurements, pics, etc. (raises hand). 🤚
BTW—noticed some folks having a hard time finding L-truck bolts, so we’ve started offering our own!
Made in-house from stainless steel (same ones we use on our external panels), and ready to roll.
what about hammer head T bolts for the rack. we are having a very hard time in the US trying to find these that will not corrode after a short time. our current option is chinese cheap quality, not stainless steel, found on amazon. any suggestions for those bolts?
What about Grenadier works L track solution?
We use stainless steel T bolts in other projects so it's not a problem.
If anyone here is into fly fishing - one great thing about that Bison top shelf is you can just run your rod through the front - if I’m chasing blue lines and stream hopping, and don’t want to break the rod down each time, I just rest it on the Bison shelf (I put foam tape around the front “windows” to protect the rod, then I have a cable management clip on the top of the rearview mirror to hold the rod tip. A 9’ rod will JUST fit - with like an inch or two to spare. Some of the other top shelf options won’t work for this (the vertical front of the shelf is either solid or the MOLLE lattice is too small to easily run the rod guides through)- and I vastly prefer to keep the rods inside rather than up top (especially in the winter - who wants to be rigging up in 20d F???).
How much longer is the stretch?! :-)
Thank you, I know it will be great when it's done
Good news.
The Left Basket for the INEOS Grenadier with inverter cutout is ready!
We have the first (small) batch available and ready to ship.
You can order directly using the link below:
Good news.
So happy! Ordered! Finally, the feeling of being the odd man out, will subside!
Thank you @Bison-Gear !
Ahhh I ordered the rear table before I seen this or I would have gotten both!!! I'll have to remember to pick that up next order...
