That BB has plenty of the features you need. If you go Lithium you really must have a DC to DC in the mix (which that BB does). Does the integrated DC to DC charger have a voltage sensitive relay? I could not find details about the charger. It maybe the 200A Isolator or that may be the On/Off switch. I am not familiar with UK descriptions.Not so many options in the U.K. but Jackary and Blueti spring to mind but I’ll probably go with this make from 12v planet
Portable Power Technology Vehicle Power Hub 2500 - 200Ah Lithium
A fully integrated solution combining 200Ah lithium battery, DC-DC battery charger, integrated MPPT solar controller & power outputs, all in a portable box.www.12voltplanet.co.uk
If I buy that particular model then I will just use the ignition live connection that I can tap into in the battery box and just rely on the battery being charged whilst the engine is running. I will use Anderson connector for main supply and maybe single pole Anderson connector for ignition live so the whole unit can be removed as needed such as supplying power in the ground tent.That BB has plenty of the features you need. If you go Lithium you really must have a DC to DC in the mix (which that BB does). Does the integrated DC to DC charger have a voltage sensitive relay? I could not find details about the charger. It maybe the 200A Isolator or that may be the On/Off switch. I am not familiar with UK descriptions.
I can recommend the scrub a wash bag. Very compact and surprisingly therapeutic rolling it around with your feet while having a beer.New heading:
WASHING (CLOTHS)
You do not need to rinse the cloths if you only use wool softer, just dry them. Use enough water to cover the cloths and get the agitation working. Corrugations really help agitation! The only use I ever found for corrugations.
- The Scrubba Wash Bag range here and
- Bush washing machine. Get a 20 litre plastic container, add some water and wool softener. Drive around to agitate and then dry the cloths. Thanks to my road buddy Barry. It works.
The 30l blue drum on the roof is my washing machine and I needed it after the lion in the top right of the photo got up and started to walk towards meI can recommend the scrub a wash bag. Very compact and surprisingly therapeutic rolling it around with your feet while having a beer.
Cheers
Steve
I always enjoy looking at your news and photos!The 30l blue drum on the roof is my washing machine and I needed it after the lion in the top right of the photo got up and started to walk towards meView attachment 7869399
Added. DMW has rock sliders as well. It is a combination rock slider and step. Weighing in at a beefy 30kg each side.I see DMW has released a bullbar and sliders
DMW Ineos Quartermaster and Grenadier Bumper Replacement Winch Bar wit
Transform your ride with the ultimate protection and style of the DMW Ineos Grenadier Bullbar. This expertly crafted accessory is designed to elevate your vehicle's durability and aesthetics, ensuring you’re ready for any adventure.dmwindustries.com.au
