What tariff is put on goods imported from Austria?Only $350 huh?
I've endured the "Harley Tax", the "Indian Tax" and the "Porsche Tax", so I should have known, but damn is everything for the Grenadier expensive.
- LabRat
- ineos tax
- Forum: Off-topic general chat at "The Grenadier" Pub
That is not the INEOS tax but the military grade tax on anything NATO plug,Only $350 huh?
- LabRat
- ineos tax
Translates as "What is the end use?".최종 용도는 무엇입니까?
Correct. The circuit is fused at 350A. I don't recall the fuse characteristics but it may have a surge rating of 500A and a continuous rating of 350A. That might explain the 500A label on the switchI wondered about this but I seem to recall it’s only 350A through the NATO socket?
If the switch wasn't marked with 500A we'd be none the wiser and better off for itI think the NATO socket itself is rated for 500A but yes a 350A fuse.
If I remember correctly…![]()
The main fuse for the rear NATO plug circuit is found on stud 3 of the 5 Stud busbar. It is a ZCASE MEGA fuse.Correct. The circuit is fused at 350A. I don't recall the fuse characteristics but it may have a surge rating of 500A and a continuous rating of 350A. That might explain the 500A label on the switch.
@TheDocAUS might have studied that fuse in more detail.
So I’ve basically ignored the fact that I have a NATO plug until now. Forgive my ignorance of its function….can my truck get jump started using it with this type of cable….or is it strictly power out?
See post 15 above, second bullet point.So since it’s the NATO plug, would you have to have it in drive or reverse with the parking brake on to get it to work? Isn’t that something of an oddity because of it stated use for a portable winch?
So since it’s the NATO plug, would you have to have it in drive or reverse with the parking brake on to get it to work? Isn’t that something of a oddity because of it stated use for a portable winch?
