AO now offers Jumper Cables with 50 mm² NATO Plug
Or you could if you want to jump start either the Grenadier or another car, just get a regular set of heavy duty jump leads and use the jump start post under the bonnet.
This day and age, it seems like jumper cables are a large bit of unnecessary kit, particularly on planned journeys. The little Lithium Jump Packs seem to do the job just as well (assuming you monitor charge status) while taking up much less space and weighing much less than a good set of Heavy Gauge Jumper cables.
Added bonus, no 'Cable Length' issues to contend with. Cause no matter how long the cables, they always seem a tad too short (kind of like winch cables)..
And they are comparatively (to this NATO plug solution) cheap!
Agreed I’ve got a Noco-boost myself. I was merely stating about regular jump cables as I really can’t see the point of a jumper cable with a NATO plug on one end as only useful one way. The Grenadier isn’t designed to be jump started from the NATO plug.
What an amazing idea, outside the box thinking!!
Not nearly as cool as using a NATO plug…
If there are two options to getting something done and one involves opening the hood and the other does not require cracking the hood then I will take option two every time. So ya, the NATO jumper cables are cool. And yes if you have the solenoid engaged like you would to use a rear winch these cables could be used to jump start the Grandier from another vehicle. The electricity does not care which direction it is flowing unless a diode has been put in place to prevent bidirectional flow. As far as we know the Grenadier has no such diode for the NATO port.
But if it requires a jump start, it's possible it doesn't have the power to engage that solenoid, so they'd leave you SOL, even if another vehicle was available. Those Fancy NATO plug cables may be of little use. And honestly, popping the hood might be easier than dealing with a NATO cap that isn't cooperative..
Maybe the 'cool' factor of having something someone else doesn't warrants the ridiculous price for some. Still ridiculously priced, for something that is limited in value, IMHO..
The power coming from the other vehicle would engage the solenoid, so that is not an issue.
I have no intention of buying these cables. I just find it to be a cool solution and keep envisioning cables with a NATO plug on both ends. Only useful for connecting two Grenadiers to each other but fun to think about in a group travel kind of situation.
Ok. I have to agree because I’m guilty of buying lots of things that look cool. 🤔
Just run an Anderson plug to the front of the vehicle from the posts under the hood. U.S. tow trucks do that and there was a time when most police cruisers were wired that way too.
That’s what I did with my Defender, then made up a set of jump leads with a 350 amp Anderson connector on one end. This saved getting under the passenger seat to access the batteries
🤔 Will it? I would think the whole point of the solenoid is to disconnect/ isolate the plug from the electrical system when not in use. How would providing 12v to the plug with the solenoid off/open allow current through to activate it?
I've done the same on multiple vehicles, defender included, going back to the late 80's. I have a very nice set of 25' heavy gauge cables hanging in the garage, probably more valuable for the copper than anything else at this point. They are just too heavy and take up too much space, in comparison to a small lithium jump pack, to be practical anymore.
I've done the same on multiple vehicles, defender included, going back to the late 80's. I have a very nice set of 25' heavy gauge cables hanging in the garage, probably more valuable for the copper than anything else at this point. They are just to heavy and take up too much space, in comparison to a small lithium jump pack, to be practical anymore.
We all buy what we like. If my truck comes with a NATO plug, and if there are accessories and tools that actually use it, I’m happy to pay a premium. There’s a definite cool factor and uniqueness to it. Personally, I don’t mind the extra space it takes or how heavy the cable is, it works for me.
I said something similar when I got the NATO socket working full time and made an adaptor to a 50A Anderson plug. It was the most expensive and probably the most complicated way of sending power to my camper but the NATO socket was there and I was determined to use it.
Stubbornness doesn't have a budget 😤
Nice! That’s exactly how I feel about it. I also like the idea of having an air compressor plugin through the NATO plug. It’s a pain having to go to the second row to use it. That’s probably the next thing I’ll do.
My GS109 also has a NATO Socket, but different. So despite the excitement about the Gren NATO, it’s just a distraction. Pop the bonnet in 30-seconds, two alligator clips, and I can use my equipment that also works with any of my vehicles.
  • ELECTRICS/NATO PLUG: Understanding the NATO plug on the Grenadier here and why you need to check your NATO plug here;
  • ELECTRICS/NATO PLUG: Using the NATO plug to power accessories, look here;
  • ELECTRICS/NATO PLUG: Check for corrosion and water ingress into the NATO plug, the topic is discussed here. One solution is to use a 50mm (2” inch) Camlock Rubber Gasket - agricultural or plumbing supplies shops have them or try eBay or Amazon. I also put Tef Gel on to the threads to hinder corrosion;
  • ELECTRICS/NATO PLUG: Re-wiring the NATO Socket to INT1 look here (yes INT1, the reference was corrected in a later post);
From this list:
Thanks @TheDocAUS for providing all of the helpful links under this post with the contributions of other members.
I got the opportunity this morning to use my NATO plug and cables to jumpstart our mini cooper. I’ve got to say, this forum is pretty special with the plethora of information shared by our small community.
