Some postulation about Zimm's question. Probably just a desktop exercise. Read past it if you're not interested.
As a wiring exercise it's a simple task. The body to axle connectors are located on the frame next to the left lower link mounts - pics. Unplug the connectors and apply an alternate 12v supply on the downstream side of the circuit (facing the axle) and the e-locker/s should energise. The Eaton wiring diagram provides the information needed to create a manual control circuit. A switch and a relay and not much else.
If you piggyback power onto those connectors the BCM won't be happy when it sees 12v come into the circuit that it wasn't expecting, and Canbus will see an open circuit if you leave the factory connectors unplugged. A dual supply arrangement is required where either the BCM or the driver can send power forward to the e-lockers but not towards the BCM. Blocking diodes would solve this, similar to the circuit protection device used by Redarc for their tow pro brake controllers (and shown in the Eaton diagram).
That simplistically deals with manually controlling the e-lockers but it doesn't address the Ineos control and BCM logic.
I understand that Electronic Traction Control (ETC) including downhill assist is disabled while the diff locks are on. I'm guessing this is why the wheel speed sensors are in the loop otherwise Ineos went to a lot of trouble to control the lights in the overhead switches. Reading around the webs this control logic seems common to other brands with factory lockers and ETC.
But what happens if a diff is manually locked by the driver and ETC does activate? That sounds like a cross-axle conflict. ETC is trying to brake one wheel but the axle is locked so what happens on one side affects the other side. This is no different to retrofitting an e-locker to a vehicle with factory ETC. I can't see anything in the Eaton documentation that requires ETC to be disabled as part of e-locker installation so they must be able to co-exist.
I see this like driving through the brakes to recover traction on a vehicle with an open centre differential. The wheels are seeing power and braking force at the same time. If the wheels do stop turning the speeds are the same (zero) and ETC will deactivate. If the diff is locked there shouldn't be different wheel speeds but e-lockers can unlock temporarily if the vehicle rolls backwards so I can't say it would never happen.
This does seem like a fair bit of work for limited gain but I can think of two immediate benefits:
1. Temporary rear diff lock in high range. Useful for a traction boost without going through low range. Towing off a slippery flat campsite is one example. A few seconds of extra ground bite is useful to get movement.
2. The manual circuit could be hot (I would suggest that's done through a VSR) so the diff/s stay locked when you stop the vehicle temporarily. Plenty have asked about this. Currently the only option is to leave the vehicle running.
Assuming the BCM can be isolated, what are the operational considerations and impacts of locking a diff without the BCM knowing about it?
