Workshop Manuals available?
I got my UN & PW via email this afternoon, but I cannot get the site to load. I'm on a MAC and have tried Firefox, Safari, and Chrome with no luck whatsoever. Plan to try again in the morning, but has anyone else hit this snag?
I found the username was case sensitive.
I got mine yesterday - will begin playing around today or tomorrow. Very interested in part numbers for the interior bits that replace this terrible piano black with something matte or green.
Well I’ve been trying to look up some stuff regarding auxiliary coolers removal and fitting incase they fall out again and can’t get the page. System buffering so likely overloaded already. Either that or Ineos are restricting my access for sharing information about removing wheel arch fenders and high level brake light 😂
I’m still waiting for email confirmation?!
It seems there is going to be plenty in the workshop manual that we so not get access to. For example checking the diff oil level, requires a special tool that we are not told what it is. Checking the gearbox oil seems impossible for the owner also. Transfer box is fill to overflow so easier.
I appreciate the access to this tool, and I understand this is Ineos delivering on their "promise", but as a system for use in a disconnected or even within a true workshop environment, it's a bit onerous. Maybe I'm dated, but I still think a logically laid out,paper Factory Service Manual, would be the most helpful.
Yes, but will require someone to sit down and write it!
Screenshot then covert to pdf then print. It’ll take time. But I intend to copy and collate some bits for my travels. Just the easy stuff. Anything technical and I’ll call in the “Flying Spanner’s” 🤔😂😂
Reactions: Max
Some one posted about the diff fluid measurement tool elsewhere. It basically looked like an allen wrench - just an L-shaped piece of metal to set the fluid height below the opening. Hopefully someone here remembers who/where that is in the archives. The transmissions (76 & 51) have online descriptions of the fluid change process as they are used in other applications. I think there are several youtube videos as well.
I get your point though. There are sure to be black walls thrown up here of there for all kinds of reasons.:unsure:
look under the post:
Diff oil level measuring tool?​
The tool probably looks like in this picture. The markings are at 20 mm / 25 mm / 30 mm from the underside the top.
From the images posted the manual has a good set out and details are well explained.
With all the intense interest in the manuals and owners soon receiving it there is one common questions that may be researched and answered.
Power steering system operation, design and operating pressures this may get to the bottom of noise issues.
Out of general interest the axles and diff lock design and transfer case design and lubrication system would be a good section to learn about.
This looks like "high tech", impossible to copy, unless you are Chinese (joke, with due respect to the Chinese, because not only the Chinese are copying, this is world history).
As someone who has bought the Grenadiers in the used market, I am not sure how one would even go about getting access. You guys are getting emails, how does ineos even have your address? Is that from the original order ?
Hi @OkGo Others have had good results using the chat tool on the IA website to ensure they have your owner details for warranty and recalls. Ask for an invitation to the manuals while you're there.
