- Local time
- 12:59 AM
- Joined
- Jul 27, 2022
- Messages
- 6,089
- Reaction score
- 13,497
That's the big debate in the UK.look after the tracks or the tracks will become closed one way or another.
suits everyone to minimise damage and if that's winching then that's what one should do.
I think the issue revolves around whether you are winching up/down/through a natural feature or damage caused by others.
In the UK it is mostly the latter, although there is much debate as to whether it's 4x4 vehicles, farmer's tractors, or others causing the damage. In some respects it is a side issue, as the ground is damaged.
With regard to the former, then there's the case that others will make that if you can't safely drive the route, then QED, the route is not suitable for vehicular access.
