The original question was whether to order the vehicle with a winch, or perhaps fit one later. The fact that ordering one from the factory includes the fitment of appropriately rated springs avoids one of the challenges of fitting one later.I wouldn't call the springs upgraded, in the tradional sense of that word, but rather just a different spring rate.
As such I'd not expect there to be a significant, if any, price difference to the other rated springs; and if of course if they're fitted on the production line there's no cost impact there either.
I am currently struggling whether to add a winch or not.
I do not really 'need' a winch. But it gives me a bit more confidence to master difficult sections. If I will once travel through Sardinia, the Pyrenees or the like, it would feel like kind of a backup.
On the other hand, I will likely drive the Grenadier on the road for at least 90%.
Ineos offers a 5.5 tonnes winch, the price is 3671,- € - which is a lot.
I ask my self, whether I could fit a winch of that categorie for that price later, including installation, wiring etc. (already have the power panel).
What do you think? What are the prices for something equally good and powerful?
I am asking myself the same question about the winch.Not sure about the weight of the Red removable winch but a ‘removable’ winch is normally just a regular winch fitted to a multi-mount kit, with appropriate plug’n’play wiring prep on the vehicle. So it’s pretty much whatever winch you want. This appears to be the case also with the Ineos option, which looks to be a lower rated winch mounted in a steel sling.
Remember that you’d almost always use a hand winch in combination with a snatch block giving a 2:1 mechanical advantage, so typically a ~1.6 tonne winch {12-13kg plus same in cable) is plenty for a light vehicle. Not that a light vehicle feels such when it’s sunk to it’s axles and all you have is a hand winch.
If you go down this route you‘ll also want a synthetic line… run the synthetic line through the snatch block(s) and do your straight pull via the steel cable.
Final thing, it’s also notable that if you’re in the middle of nowhere hand winches can be used for various lifting and pulling tasks outside the realm of vehicle-mounted... side ways pull if your vehicle is resting on it’s side in a washout; righting a rolled vehicle; doing bush panel repairs; hoisting an engine/transmission* etc etc.
* not recommended of course, but when you’ve gotta do what you’ve gotta do…
The hand winch you appear to have selected is enormous. I assume it was just to illustrate the type rather than the model?Thank you, you have all brought very plausible arguments.
In fact, I don't feel particularly comfortable with the ~ 50kg additional weight, which is mainly just being driven around. And bemax' arguments regarding consumption / efficiency are hard facts.
DCPU's hint was a enlightenment and will probably become my solution. It's not about showing off a winch for me, but really about a 'backup'. And a Tirfor (in German "Greifzug", I had to look it up) seems to be a really viable solution. This is used by firefighters as well as the military, so it should be a solid solution. With certain limits, but that's the price. And it's of course true that a winch needs attention.
In return, 3670 euros is a decent saving, for which I can not only buy a good Tirfor and a reasonable set of recovery gear but have as well still enough left to completely fuel up my Grenadier 15 or 20 Times.
Yes, the forum gathers a great deal of knowledge and experience. Thank you all!![]()
Have you got some photos of that setup?I use a Greifzug with my Defender. The good thing about it is that you really think it over before you bring your car in a situation where you need it. It is slow slow progress you make, working with it!
But it is somehow satisfying as well to see what you can move with one arm…
My tirfor is quite heavy and needs two aluminium boxes including steel rope and everything I need for it.
No, sorry. But here is the bundle in a shop:Have you got some photos of that setup?![]()
You're right, it's a monster.The hand winch you appear to have selected is enormous. I assume it was just to illustrate the type rather than the model?
Don't forget you're looking at lifting loads with a Tirfor spec.Another thing is weight. A good Tirfor (say 3200Kg) and a cable quickly sums up 50 or 65 Kg, depending on the brand and the length of the cable. The cable has to be made of steel due to the functioning principle of the Tirfor, so it is quite heavy. A short steel-cable would however work if you extend it with a plastic rope and only use the steel part for winching. This saves some kilograms.
Maybe it's better to transport 65 Kg for 10% of the time than 45 Kg for 100% of the time. But you have to secure this load whilst driving, it can become a dangerous missile.
There was another idea: The removable winch. Works front and aft. Does anybody know what it weighs?
Well, that's helluva a bundle!No, sorry. But here is the bundle in a shop:
Dönges Mehrzweckzug-Satz DIN 14800-MZ16 Greifzug
Neu konzipierter Satz nach DIN 14800-5:2013-12. Kasten 1: 1 Stück Dönges FireBox nach DIN 14880-1-LM (600 x 400 x 220 mm), mit Einteilung und…shop.doenges-rs.de
Thanks.No, sorry. But here is the bundle in a shop:
I would not go for less than 20m, ideally 25m.Also, you probably don't need 20m of steel cable. What you need is a cable with approximately the net towing length normally required. You can extend this to the car with a plastic cable. Saves a few kg too.
Not sure why we can't have the front receiver hitch in the UK?Fits in the 2"receiver but may fit in the front tow hitch in Aus
View attachment 7792200View attachment 7792201
Totally agree with that, but what you said initially, and what I was questioning, was:The original question was whether to order the vehicle with a winch, or perhaps fit one later. The fact that ordering one from the factory includes the fitment of appropriately rated springs avoids one of the challenges of fitting one later.
I sell everything the fire departments and other helpers need
For the winch option (£3,185) we've been told (Justin Hocevar) you need the High Load Auxiliary Switch Panel and Electrical Preparation (£1,060); if you now want the CTEK unit (a Smartpass 120S) that comes with the Auxiliary Battery then that's an additional £570.the fitting by the factory is a no brainer especially with the ctek unit. Also it's protected inside the front bumper and gets higher rated springs.
www.red-winches.com
We know the alternator can pump out 250 amp, which will provide most of the power needed. The main battery, and if you have an aux battery, are both 105ah each.It also needs clarification on where the winch will draw power from when an auxiliary battery is fitted. The starter battery ~ as that's where it must come from if you don't option the auxiliary battery.
There's a big difference between the vehicle engineering team and the website developers... but yes, that's exactly what has happened.I wonder if Ineos really sells a winch which wouldn't be functional without additional equipment - without implementing this in the configurator as a mandatory upgrade?
