Leave the vehicle for a few hours and then start again to try the diff locks.
She should look around in the coffee bars near by.She went off looking for some Italian authority at the airport. Turns out they are mythical beasts.
Had this two or three times now, looking like so "0 - 0 - 0 - 0". Came back after a while with the correct figure.On start up the odometer reset to 0000. Same after turning it off agsin. Then back to normal 425 miles next time
The rear diff would not lock ~ that's a hardware error. And because the front won't lock without the rear being locked first, then that's the same as a hardware error!OK, from what I've been told the only warnings/malfunctions you should take notice of are the ones on the screen behind the wheel, according to the IA guys all notifications are software related. I know it's not much help but at least you know it's not malfunctioning hardware
Correct, what I mentioned was related to me from an IA tech. I'd be taking that up with the dealerThe rear diff would not lock ~ that's a hardware error. And because the front won't lock without the rear being locked first, then that's the same as a hardware error!
I don't mind a whole series of amber warnings, or notifications of secondary systems not available but a red warning on the airbags really doesn't sound like something that should be ignored.
At the airport?She should look around in the coffee bars near by.
Yes, but the bull elephant doesn't solve the problem either. He only adds to it.. I can just imagine those Grenadier safari prototypes in Botswana or Namibia having that problem when a bull elephant is charging at the rear of the vehicle full of tourists.
Agreed just sort all this stuff out before the safari or any other potentially critical situation.Yes, but the bull elephant doesn't solve the problem either. He only adds to it.
I realise that this is not a good option. I would only use it to find out if it is a pure display problem and therefore a software problem.
Absolutely. There are coffe bars as well, and you very often find these guys there - especially if there a some beautys in there drinking their espresso.At the airport?
But in the evening everything is shut and the baggage area is echoic...Absolutely. There are coffe bars as well, and you very often find these guys there - especially if there a some beautys in there drinking their espresso.
Reading about the crazy amount of problems that seem to be coming from (even slightly) low voltage due to incomplete battery charging or the effect of small parasitic drain when the vehicle is not being driven, I am puzzled.
If there is this vulnerability, why do vehicles not have circuits to regulate the voltage coming from the battery before it gets into the vehicle electronics? Ten years ago I was involved in the development of a battery powered handheld electronic device and remember what a game change the then new availability of electronic voltage regulation made to system reliability in the field.
Then why all the problems with low battery voltage (from the vehicles sitting for so long at the dealers or at Ineos) setting off a cascade of error messages in the Grenadier?They have. Every car has a regulator keeping the voltage around 14,4 V. For decades.....electro-mechanical and since the 70tys more and more electronic ones....
This is not a pure direct current, as car generators produce alternating current. It has small rectangular portions, Each manufacturer of electrical vehicle equipment exactly knows this and takes this into account....
AWo
These are good faults to have fixed. The steering line rubbing on adjacent is a major potential issue - but fixed. We will need to have our dealers thoroughly check for issues noted on this forum (before handover!).Collected my Grenadier this afternoon after going in for fault diagnosis. Apparently everything has been checked inc problems identified on other vehicles. A wiring loom has been re routed as a bend in it was too tight a power steering pipe moved/adjusted and clips/protection added where there is potential for rubbing pipes. I’m told a very thorough check over has been carried out inc numerous test drives. I feel reassured this has all been checked.
one software fault showed on the drive home “ecall error”
Rhino rack roof rack has been fitted and seems a very solid piece of kit.
Hopefully can get the software update before shipping if not will hope to get done in South Africa
I’ve had the odometer momentarily read 0-0-0-0 and return to correct reading whilst driving.A new one today. On start up the odometer reset to 0000. Same after turning it off agsin. Then back to normal 425 miles next time.
For 15 mins today I had no warnings , not even the TPMS.
Thought the INEOS man must have visited in the dead of night.
Ahh TPMS warning back - how very reassuring .
