It's a reasonable explanation for some of the issues.I am going to sound completely idiotic here but i think this needs to be said .
No need for lawyering up and class actions yet
unlikely.I am going to sound completely idiotic here but i think this needs to be said .
What if all the crazyness is simply because vehicles have been built and sat around for so long with brand new batteries that never got properly cycled ? Is this just a matter if taking the car for a long drive at highway speeds to get everything settled in ?
I remember when my bmw had a battery ready to die i would get all sorts of weird stuff going on .
Maybe i am naive or simply stupid who knows ….
Time will tell i guess …
So just gremlins then?unlikely.
A cycle is a full discharge and full recharge.
The Grenadier leaves the factory with a fully charged battery, gets transported to agent and sits there for 6 weeks. Maybe started a few times but it's hardly likely that the battery will be fully discharged.
I agree to what @mgohillbilly answered.It’s interesting as a new boy to the forum to see that there are a lot of threads in which people express frustration at the delays in delivery and others bemoaning software faults in the as delivered vehicles
I’m sure as a manufacturer there is pressure on the one hand to delay release to address all or at least most issues and on the other hand pressure to get cars into the hands of customers
Of course they are. Electronic sensors provide vast amounts of data, much of which is nonsensical (no pun intended). This is knowledge from the first semester for electronics engineers. Temperature, humidity, engine temperature, even vibration - this is the normal habitat of sensors. This is their fateful destiny.Results:
- all yellow error messages are caused by a deviation of current „values“ or measurements from the standard values
- they are the result of multiple things: temperature, humidity, engine temp, and whatever else
If they say August be prepared for a Christmas gift.Fingers crossed thus software flash doesn't take long to come
Great explanation! Spot on and I agree with your Ineos criticism.Of course they are. Electronic sensors provide vast amounts of data, much of which is nonsensical (no pun intended). This is knowledge from the first semester for electronics engineers. Temperature, humidity, engine temperature, even vibration - this is the normal habitat of sensors. This is their fateful destiny.
The trick is in the filtering. I've had many a battle with implausible data from sensors. But since they are capable of providing thousands of measurements per second, you can (and actually have to) write algorithms that throw away implausible values. This is usually done using a Bayesian minimum variance estimator (often implemented as a Kalman filter). This is exactly the kind of knowledge that makes a Bosch system a Bosch system and makes a car a reliable car. And it's why these high-end products are so expensive.
After filtering, you average out the values and get a (reasonably) reliable result.
I have often seen OSB logs from my old W203. It produces dozens of error messages every minute, but if they are found to be implausible, they never reach the cockpit and are just stored as an MRU list in the ECU memory only for debugging purposes.
I find it totally unacceptable that INEOS unleashes such an immature system on the customers and ruins its trust, which is the perfect way to shoot itself out of the market after the disastrous web launch and the totally insane billing and the just plain wrong built cars (wrong color, wrong engine ... unbelievable) as well as the completely incompetent "Customer Support".
The technician is of course right with his explanations, but what good is that? In the end, he's just the whipping boy who has to take the brunt of everything that management has screwed up.
What a shit.![]()
Maybe they sourced it out to Bangalore where the developers copied & pasted from the TukTuk source code.This is pure speculation, but their website has been noticeably buggy (I wasn't even able to make a reservation for a long time) and showed signs of not being properly tested. Maybe this points to a deeper culture problem? Was the desire to make an old-school car so great that no thought was given to the software, and they ended up hiring a sub-standard team?
Have observed similar snafu situations arise in avionics and combat systemsOf course they are. Electronic sensors provide vast amounts of data, much of which is nonsensical (no pun intended). This is knowledge from the first semester for electronics engineers. Temperature, humidity, engine temperature, even vibration - this is the normal habitat of sensors. This is their fateful destiny.
What a shit.![]()
Agree. It definitely seems to me like they may still need to find out the correct sensitivity of many systems. If all these sensors are throwing up measurements that are simply being identified as "out of range" then it triggers a warning light or alert. I imagine it will take Ineos, with the help of early adopters' real world experiences, to fine tune what "out of range" actually needs to be before it results in a warning.Of course they are. Electronic sensors provide vast amounts of data, much of which is nonsensical (no pun intended). This is knowledge from the first semester for electronics engineers. Temperature, humidity, engine temperature, even vibration - this is the normal habitat of sensors. This is their fateful destiny.
With respect ot what @PBD has experienced, I find it totally unacceptable that INEOS unleashes such an immature system on the customers and ruins its trust, which is the perfect way to shoot itself out of the market after the disastrous web launch and the totally insane billing and the just plain wrong built cars (wrong color, wrong engine ... unbelievable) let alone the completely incompetent "Customer Support".
What a shit.
Edit: refinements
Yes. Clearly someone let them get wetSo just gremlins then?
Do they have those in Hambach?
I knew there were elves. Now we have gremlins. It's a Euro thing.Yes. Clearly someone let them get wet
I hear you there Denis.Have observed similar snafu situations arise in avionics and combat systemsthe complexity can be overwhelming at times....
Or the reverse question, for those currently not having any alerting issues, and never did…do you have the auxiliary battery option on your vehicle?Out of interest does anyone who is encountering the bing & bong sound and light show (alarms and warning lights) have an auxiliary battery setup?
It's part of the PDI:Its definitely true that a depleted battery can cause issues on modern vehicles. Let’s hope that most of these are caused by vehicles sitting around for a long time.. I’m surprised that dealers aren’t charging batteries or running vehicles before delivery.
I thought that was one of the items in the PDI form - check battery is charged above a certain level.Its definitely true that a depleted battery can cause issues on modern vehicles. Let’s hope that most of these are caused by vehicles sitting around for a long time.. I’m surprised that dealers aren’t charging batteries or running vehicles before delivery.
