What Rocksliders / Side Steps did you choose
I have the White Knuckle Off Road sliders on my Grenadier and absolutely love them. I installed mine with zero issues. Just used some jacks and did it all by my lonesome. @Slov If you are even slightly handy and have access to tools and a jack you can definitely do that by yourself! It does help if you have someone but if I can install mine you can most likely do the same with no issues.
For sure man. I visited the Owl Outdoors shop yesterday since they are local to me in Mesa and they gave a tour of their facility where all the manufacturing takes place. I think the only parts to have installed professionally would be the full skid plate and an aftermarket fuel tank due to lack of space in my single car apt garage. The rock sliders I can easily do on my own based off your guys testimonials!
+1 on White Knuckle. 20º no rear kickout variant.
[edit to attach photos]
That looks fantastic! Did it require any drilling or modification to the stock body or frame?
I love the look of the Agile Offroad best, but disappointed it requires drilling into the factory body which is a showstopper for me. Any other slider options that is literally plug and play, no modification or drilling into the stock frame/body whatsoever?
Thanks!
Thanks!
Check out the Buzz Overland rock sliders. I’m considering them myself. They fit to factory mounting points, have hilift jack points and are stainless steel for durability.
Thanks!
They are bolt on, plug and play, mounts to the holes already there. No modifications needed. Shipped on a pallet, very well wrapped. They're heavy. If you're crafty with a jack and jack stands, they'll go on in an hour by yourself. I used a rolling floor jack in the center -- hindsight says, fashion a larger jacking area with (parts of the pallet?) whatever you have on hand -- which i didn't do... instead I played the "lets see if I can balance this" game... use jack stands at the ends for safety.
I ordered my Buzz Overland steps from them as well back in March. I called OK4WD yesterday to see what the holdup was. Apparently, Buzz had a switch over with manufacturing equipment for their welding. Not sure how true that is, but that’s what I was told. They said that they should be arriving here sometime near the end of July since they left port and are on a boat.
Have you had any update from Buzz Overland or OK4WD yet on these? I ordered rear drawers at Overland Expo Flagstaff May 15-17 and the owner estimated that it would take me about 2 weeks to get them. I'm still waiting and keep getting the "the ship should arrive at port soon" answer.
The last update that I have is that there was a delay with the shipment at the port and everything got pushed out to August 10. We are now past that point, and I haven’t received any notifications from them. If I didn’t want these steps so bad I would have just canceled, but they are the only thing like it with the stainless steel construction.
Unrelated, but we have been bringing big stuff into the US and scheduling ships has been a real nightmare.
Stainless steel seems to be the go to as a material for sliders. I'm assuming to prevent rust on bare metal?
These worked well for me. Close to the body and wide enough to be a step. Installation is straightforward with only two sizes of bolts. Installed by myself with two jack stands and a floor jack. They also provided blue thread lock. It is true that there are no printed instructions, but there is literally only one way these can be installed to the factory mounting points. Marc from CA Tuned was helpful when I called about the instructions. I recommend them.
