@douggie Today, I was able to swap all the sensors of my winter tyres to AUTEL MX sensors and programmed them via the AUTEL TS508WF device. I've just cloned the IDs from the factory BFG ko2 tyres. What I can see clearly, the sensor IDs are at fixed locations and the Grenadier do not automatically detect if you swap tyres. I had swapped the front tyres about two months ago, and that was still visible on the screen.
So, as you are suggesting, the best procedure is to write down the original IDs of all five tyres (as these IDs are somewhat hard-coded in the Grenadiers ICU), and after rotating tyres just clone the IDs again - job done!
Not sure if INEOS works on an improvement of the TPMS software in the future, but currently the use of the AUTEL device and sensors is the best approach to get the most flexibility, and it's not expensive at all.
