Friday a.m.: returned the homemade transmission skidplate to the Grenadier (removed for axle pinion and transfer case seal work). Took 15 minutes.
Friday p.m.: installed Agile Offroad's gas tank skidplate. Took 1.5 hours and a lot of choice words.
I did not know or expect Agile's skidplate not to have its own brackets. It bolts to the existing factory gas tank skidplate - which is not a bad solution, just not what I expected. It also implies the factory skidplate to have ... the factory shape, which mine didn't - so some time was spend bashing the factory unit to shape and shooting the scuffed areas (with factory powdercoating flaking off) with RustOleum.
The new add-on skid requires holes to be drilled in the factory unit. Reinstalling the assembly was helped with a trolley jack under the skidplate - I probably could have "bench-pressed" the skidplate but it would cause more aggravation.
Now I have about 0.25" less ground clearance and plenty of room to stash sand and small pebbles in the gaps between the factory and add-on units.
But I'll also have a bit more peace of mind - knowing the factory skidplate could be bent by not much more than an angry look.
Saturday early a.m.: drove from San Diego to L.A. to meet other Grenadier owners. Stu Barnes, Bill Ruttan, and Tony Herrera showed up at the Motoring Club in West Los Angeles - good to meet you all!
