Really I won’t. I have no perceptible impact on my own life no matter the effort.Always just out of the running, eh? You'll catch more flies with honey... as the saying goes.
I agree 100% about the bending angle of the front drive shaft, that is a faulty design and there are some owners with technical knowledge who see it the same way, but there are too few...unfortunately it is not enough to change the front pinion angle, because the problems come from the angle on the transfer case or this joint is more affected.... a very annoying situation.I have had mine since September and now have 14,000 miles on it. The software update fixes most of the ADAS issues. I intentionally ordered mine with safari roofs because I’m sick and tired of leaking sunroofs. Every car I have ever owned with a sunroof eventually leaks. At the moment that includes a F150 King Ranch and a Cayenne GTS both of which leak.
The turning radius can be improved if by adjusting the stops if it is bothering you that much.
The only issue that I have had is the driveshaft was replaced at 12,000 because of a failing front CV joint. In fact, this is the only real issue with the design. They pinon angle is utter shit causing real issues with the CV’s. The high angle is causing constant flexing of the rubber boot which causes heat and destroys the boot leading to it dumping grease and eventually failing. I predict that these becomes a recall and an entirely different driveshaft gets designed or even better at replacement front axle with an appropriate pinon angle.
Otherwise it’s a damn great truck. My favorite car I have ever owned.
Yep. You’re in 11’th place.
I was essentially making your argument, the history of that conversation was that i had seen what i considered a $200k Gren for sale at my dealer. It had an ineos window sticker, the dealer had it on the lot and the dealers sales guy tried to sell it to me. If you want one you can now reserve one on the ineos Gren corp website where i ordered my Gren from. I was told by this other poster first that I had made a typo, then that it wasn't a proper Gren because it had portal axels among other things not available on regular grens out of the factory. I pointed out as you did that the gren was built totally of parts from other MFR and ineos maybe just made the sheet metal. I further pointed out that many of Grens standard options you check on the order form are installed at the dealer and not the factory.This isn't accurate at all. While the brakes are brembo, the seats are Recaro, the springs are eibach, the axles are Carraro, etc. None of them are simply off the shelf components. Every auto manufacturer has parts built by other companies. That's literally the car industry. Ineos just sed names that are easily marketable and recognizable.
Toyota uses Bilstein dampers on their TRD Sport and Off Road models, but they aren't generic Bilstein shocks that were sitting on a shelf, they are purposely designed for the vehicle.
There's nothing "modified" or "mods" about it.
They still want go to Walmart with their usual mates , without incurring jibes about French cars?I can't believe someone with a Grenadier also is considering buying a Ford Bronco Raptor. These are so far apart and usually, so are the people that drive them. One of them is is a retro overlanding beauty, built with intention, and the other looks like someone glued on some shitty oversized plastic mud guards on a jeep. I don't get it?
Yes it looks like it was glued together out of parts found laying around but it is a beast off-road. I have driven one in the dirt and it is likely even more capable then my Grenadier.They still want go to Walmart with their usual mates , without incurring jibes about French cars?
And just so you know, a bronco raptor would be a wild carnivorous horse. Which doesn''t makle any sense.
Grenadier is the Swiss army knife thoughYes it looks like it was glued together out of parts found laying around but it is a beast off-road. I have driven one in the dirt and it is likely even more capable then my Grenadier.
The Bronco Raptor is a world class SUV. A technical marvel from Ford Performance. Amazing off road at any speed and on road at any speed. ZERO issues 8K miles in. Bronco Raptor school was an eye opening experience for me.I can't believe someone with a Grenadier also is considering buying a Ford Bronco Raptor. These are so far apart and usually, so are the people that drive them. One of them is is a retro overlanding beauty, built with intention, and the other looks like someone glued on some shitty oversized plastic mud guards on a jeep. I don't get it?
Respectfully, 8k miles is not a gauge for reliability.ZERO issues 8K miles in.
My brother has 35K - zero issues. Bone stock. Respectfully.Respectfully, 8k miles is not a gauge for reliability.
The whole fun in it right now is you have no idea how the tide will turn - an entire community of owners prepped for the zombie apocalypse but have no idea if their purchase will be supported a year from now. Imagine what a bunch of old dudes would do with their time if they couldn’t gripe about their rheumatism.Quick sweep of this forum and I would say that even the strongest of fan boys have had some issue(s). There was something like 115k Broncos sold in 2024...Ford likely sells more Broncos in a month or two than IG in its life time. Plenty of data on Broncos but it is really hard to talk about IG reliability as nobody tracks it or.... is even interested
Disclosure - not an owner, just a lurker waiting for the tide to turn (one way or the other).
