Go with the 2026 or the 2025?
Hi folks. I'm waffling like crazy and could use some help from the experienced Grenadier owners. I spent the afternoon in the '26 the other day and the new steering and HVAC are great! I was sold and ready to purchase. However, I really want the Wolfbox mirror and front and rear cameras for better blind spot, better visibility, etc.. All was set, but then I saw the '26 has a camera in the rearview mirror so if I replace it or cover it, I will get a warning message that endlessly pops up saying "limited visibility" on the center screen as well as a warning light. This will drive me crazy.
I then went back to the '25 and thought, ok not all is lost, I'll get one at a significantly reduced price and just do the steering damper with some of the money saved and I'm good. The problem I see here is with the HVAC issues. I live in Maryland and have to have a dependable HVAC. I'm too old and am spending too much money not to.
So what do I do? Do I get the '26 and live without the Wolfbox that after driving for a few hours, I feel I need or do I get a '25 and roll the dice on the HVAC because maybe it's not as bad as I keep reading?
Side rant, I absolutely hate US laws requiring yet another nanny....
I own a 2024 Fieldmaster with the Rough Pack option, which includes the BFG K02 tires. After I test drove the vehicle and expressed some concern about the steering, I asked the dealer to provide me a printout of the results of the wheel alignment they said they had performed. Sure enough, the alignment was out of spec, especially the caster setting, which they corrected. This adjustment helped with steering stability at highway speeds. My first modifications to the vehicle were to install a Fox Steering stabilizer (the non-adjustable version) and adjust the steering bump stops. The new steering stabilizer works great, allowing the steering wheel to mostly return to center and the adjusted bump stops provide for a slightly tighter turning radius.
I have had no issues at all with the HVAC system. I've made sure that the coolant tanks are topped off to the max level and the HVAC system was fully bled of air.
I also installed a Wolfbox and I am pleased with the rearview visibility. To improve the driver's and passenger's sideview, I installed the Suma mirrors...they are excellent. With the combination of the Wolfbox and the Suma mirrors, I have virtually eliminated any blind spots.
Take the 2025 and spend the savings on making it the vehicle you want. Get an aftermarket stabilizer, get a decent alignment, make sure the dealer has bled the coolant system and then bleed it yourself after getting some miles on it.
Is your coolant expansion tank leaking? There will be white crusty residue along the seam of the plastic tanks
I’m not an owner yet. Just doing my due diligence. Not sure what coolant and purging everyone is referring to and how often does it need to be filled? Seems quite troublesome and inconvenient.
Easy peasey. You may be lucky and get one where the dealer has done it properly pre delivery. If not you should not have to do it but it is what it is. Five minutes of your time, once done and settled down you may not have to do again. It’s a BMW engine quirk, the thing that delivers so much of the pleasure also deals out a little bit of pain now and then.
You need to realize these vehicles have their quirks and require a bit of patience and an inquisitive mind to get right. It may not be the right vehicle for you.
