Vehicle mounted twin air compressor
2:34 PM
Yes sure. I don’t know that system. The only ones I’ve seen on unimogs and MAN trucks look vulnerable although they wire solid pipes
I'm wondering if the plastic tubes seen going into the axle ends could possibly be this rather than axle breathers?
Pfk
5:34 PM
Dubai, UAE
Anyone had any thoughts, or perhaps previous experience or observations, about installation of a twin cylinder compressor?
Particularly interested in mounting location, preferably not in the interior. Previously was using a portable single.
if it fits, i plan to install it on the inside of the spare wheel. its common on jeeps, broncos, i dont know if fitment allows on the grenadier
2:34 PM
Third vote for them being hot and loud. I've got the ARB twin mounted in the cubby, just aft of my right rear wheel (Tacoma). I've had one electrical fault, but no mechanical problems with the unit. They are pretty tough, but I'd prefer to have it inside the vehicle. I'm pretty sure it will last longer and be more reliable if its inside the cab some where. No way around the noise and heat though. Its a conundrum...
Doesn't the boxed version give you the best of both worlds?
Pfk
5:34 PM
Dubai, UAE
Super, not seen that - I’ll investigate.
It should look something like this under the wheel , hope it fits similarity on the gren otherwise it’s probably gona go under the seat
globalgregors
11:34 PM
Sydney NSW, Australia
Oh, interesting. That might take some tinkering with the reverse-mount spare but is certainly worth a look.
Global Grenadier 0076
9:34 AM
One potential problem on the Gren. Remember the rear wheel is mounted “backwards” in that the face of the wheel is against the door and the cavity is facing forward to be used as a storage area with the one wheel cover. Not sure if that’ll leave enough room.
2:34 PM
Yeah, mostly. The noise and heat are not a problem, but the unit still gets really dirty, and I think that was a factor in the electrical fault I had. While it is in a cubby, and I have a topper on the truck, the cubby has drainage holes that are conduits for all the crap you drive through: dust, dirt, mud, magnesium chloride that they put down on icy roads. In a future set-up, I'd like the compressor inside a fully-sealed vehicle, but that's when the noise and heat become a problem to solve.
Jean Mercier
GG#920
3:34 PM
Sint-Martens-Latem, Belgium
While googling for the ARB compressor, I found a shop, not that far from my place, unknown to me, with the compressor and a lot of other stuff, the site is in English!
I think I will have to visit that place :cool:
Jean Mercier
GG#920
3:34 PM
I saw also the ARB "single" (my definition ;) ), wondering what are the main disadvantages of this one compared to the "twin".
I have no compressor experience. But I bought recently a cheap Chinese compressor of 24 €. I tested it, it works, but is indeed very slow!
9:34 AM
Is the ARB you mentioned more for locker activation?
Jean Mercier
GG#920
3:34 PM
It says "it can be used for locker activation" therefore I would guess it wasn't designed only for this.
It also says: "with air output for up to four tires (35″- 37″)"
Pfk
5:34 PM
Dubai, UAE
I had not thought of the reverse mount in the gren… good point
