Transfer Case Gear Lever - pin
Mine just dropped out! This is a pain as I use low and locked a lot.
I was about to post for help but I have fixed it.
Here’s how in case anyone is interested.
Remove the 4 Allen screws from the grey surround
Gently pull up the gaiter. It pops out the grey surrounding can be left where it is.
Pull the gaiter up over the knob.
Now you can see two black plastic clips that locate on the grey shaft.
Gently pry these clips away from the grey shaft and the whole thing will slide off.
Set that aside and remove the spring and the metal rod that it sits on.
Make note of the orientation of the metal rod. It has a machined flat section that faces rearward.
Push the metal rod with the spring on it up into the knob. Look through the hole that the little pin fell out of and once you see the hole in the metal pin line up insert the little pin.
Now push the whole lot back into place until the two black plastic clips locate on the grey shaft.
The hole in the lift ring is oval so the pin is loose in there. I put some hot wax glue in it. Hopefully it holds.
Many thanks ,Tom for your reply and advice .It is so comforting to know that there is somebody who knows whois ready to help you
I wonder why the dealer said the had ordered a Bowden cable .I could not find a diagram showing where this cable goes and what it's purpose might be
Many thanks again
Thanks Tom, mine got stuck in low box today a couple of days before festivities. I asked my dealer Lloyd Allroad Carlisle who were excellent, given its Sunday , who replied just as I was screwing the top plate back on !
Love the forum 👍
That looks great. Much better than my velcro cable tie. Did you have to remove the knob or do those rings stretch.
Knob stayed on, the ring is able to stretch over it. You feel like it may stretch apart but it did make it. I purchased a pack of 4 on amazon (forthee brand) for like $8.
Actually I had to google "silicone wedding band". There is literally a product to empty every man's wallet!
I don't wear a wedding band nor carry a wallet. But if you are not so tactically ready, or a hobbit at heart, I can see why such bands might appeal.
