I had this issue and reported it to dealer when in for transfer case replacement last year so they should be aware of the issue that's if dealers are sending customer reports back to the mothership .
I know this is a frustration at IA. Dealers need to raise tickets with them for them to see the trends in items that fail. If IA are not notified then they can’t implement things on the line, at least that’s the gist of it.I had this issue and reported it to dealer when in for transfer case replacement last year so they should be aware of the issue that's if dealers are sending customer reports back to the mothership .
You forgot to include the roll of fencing wireThe electrical kit is in the same box as the mechanical repair kit
I had the same problem.
As the pin was not available separately, the whole gearshift was replaced.
If I remember correctly, the pin is 24x3 mm.
I'm going to get 3.1 mm dowel pins as a replacement!
So far I've only kept them in the car as a spare in case the new one falls out againhave you try this solution with the Mecanindus pin ? it good to slide in the lever ?
Shh! That's far too obviousHas anyone thought of Loctite Engineering Adhesive?
Folks with the zip tie fix, mind taking a photo?
Unfortunately IA didn'tHas anyone thought of Loctite Engineering Adhesive?
I'm surprised this hasn't come up earlier (or I missed it).Has anyone thought of Loctite Engineering Adhesive?
Preparation "H", or similarWhat about just a dob of hot glue in the hole?
As a doctor , I feel some people may not knowWhat is this Preparation H?
