Actually, to clarify, the breakaway cable pulls out a pin which locks the trailer brakes. So when the cable snaps the trailer brakes are fully applied.Too different operations, whilst US and Aus attachments are a secondary coupling to prevent detachment of a towed trailer/caravan. With an overrun braking system it is the opposite, if detached from the tow hitch, the overrun cable pulls on the handbrake tight bringing the trailer to a stop, then snaps to permit separation of vehicle and parked trailer.
For those NA and Aus members who haven't seen a UK and EU breakaway cable
Method in my madness - first time for everythingI tend with a heavy trailer (in the UK) to supplement the breakaway cable with a non-sacrificial chain of sufficient length to allow the breakaway cable to apply the brakes and break before the chain goes tight. I bunch up the chain with a weak cable tie to stop it dragging.
My thinking is that if the trailer becomes detached the brakes will be applied but I may retain some ability to steer it as it slows and ensure it stays on my side of the road.
The chain must of course be long enough to allow the breakaway cable to work as intended.
Stops the trailer frame front V dropping to the ground and digging in, and thus upending your day!Cross chains? Not familiar with that term.
You can see it here in my camper hookup.
The left side safety chain connects to the right side vehicle anchor and vice versa. The crossed chains form an X which causes the van to self-align to the vehicle hitch if it disconnects and drops down.
A common mistake is to put the D shackle in the last (end) link of the safety chain. The provided chain is typically longer than is required due to different height tow vehicles. On many vehicles using the last link will allow a disconnected A-frame to hit the ground. The safety chains should be crossed and shortened by moving the D shackle further up the chain so the A-frame cannot hit the ground but enough free length is retained for turning.
You can see I have shortened my chain free length by five links and the excess chain is secured.
This is a Cruisemaster D035 pin hitch.
What mods did you make to the big green power supply to get around the apparent 85km/hr shut down issue mate? I assume that has replaced the typical anderson plug set up?
And what be this?
I wired a rear anderson plug to the live side of the nato plug supply relay via a 50amp breaker and an 80 amp fuse. Means its live all the time. Was going to wire a relay to an ignition switched supply but have not got round to that yet. I just pull the anderson plug as required to prevent car battery drainingNATO.
There is a contactor (big relay) under the right rear trim. That needs to be energised to power the NATO socket. It's normally controlled by the Body Control Module with all the rules we know about. I ran an ignition switched wire to the trigger coil side so it closes as soon as the key or the PWR switch is turned on. See my post here. https://www.theineosforum.com/threads/nato-plug-socket.12410957/post-1333210105
There's other options, e.g.
Thread 'Re-wiring NATO Socket to INT2' https://www.theineosforum.com/threads/re-wiring-nato-socket-to-int2.12419070/
Those cords are just elastic tethers to secure the DC Anderson cable and the trailer cable. Because I'm using adapters on both (NATO to 50A Anderson and 13 pin Euro to 7 pin Aussie), the camper plugs have a bit of strain on them. The tethers relieve the strain during turning and will also stop the camper plugs hitting the road if one does come apart.
The proper solution is to replace the 7 pin and Anderson plugs on my camper with a NATO plug and 13 pin Euro plug, but then no one else could tow it and I would need to swap them back when I sell it. This works.
This is how it's supposed to work. If the hitch fails, safety chains keep it attached somewhat to the vehicle but the brakes get locked and the vehicle going forward can keep the trailer from causing all kinds of mayhem if it was free in traffic. The locked brakes keep the tension between trailer and tow vehicle allowing a somewhat controlled stop to the side of the road.I tend with a heavy trailer (in the UK) to supplement the breakaway cable with a non-sacrificial chain of sufficient length to allow the breakaway cable to apply the brakes and break before the chain goes tight. I bunch up the chain with a weak cable tie to stop it dragging.
Yep, that's the smart way of doing it. Which explains perfectly why I went a different wayI wired a rear anderson plug to the live side of the nato plug supply relay via a 50amp breaker and an 80 amp fuse. Means its live all the time. Was going to wire a relay to an ignition switched supply but have not got round to that yet. I just pull the anderson plug as required to prevent car battery draining
