Third party sealed snorkels for the IG and QM
TheDocAUS
4:16 AM
Eromanga
GRENX OEM STYLE SEALED SNORKEL (ALUMINIUM)
Australian based GrenX has three models with both a sealed snorkel and sealed airbox. Forum on GrenX snorkels is here.
The first is a sealed aluminium version that looks like the OEM Raised Air Intake, rather than asealed snorkel. It is a bolt on replacement, requiring no cutting of panels. It is the most expensive of the three models. FItting time is between 6 to 8 hours as panel need to eb remvoed.
GRENX 4.5” STAINLESS STEEL SNORKEL SYSTEM (FORWARD FACING)
Look here.
GRENX 4.5” STAINLESS STEEL SNORKEL SYSTEM (TEARDROP REAR FACING)
Look here.
NON-SEALED SNORKELS/RAISED AIR INTAKE
D&G Europe
D&G has a Hi Flow Stainless Steel Snorkel for the IG and QM. Note: the description does not say it is sealed and no mention of a sealed airbox.
The opening of the snorkel faces upwards.
OEM
INEOS OEM Raised Air Intake (RAI) is not sealed either.
Concerning the pod filter differences noted on the GrenX website - The ( oil soaked? ) cloth based variant looks quite similar to a K&R RE-0920.
Personally I’d go with a multi-layered / oil soaked foam filter over this if you’re in a high dust environment. I suspect the cloth pod filter was intended to deliver increased airflow ( possibly more HP ) - likely at the cost of reduced filtration.
BTW in case it wasn’t already known - I believe the GrenX snorkel and airbox system is ( currently ) being manufactured by Canna Fabrication.
D&G Europe
Opening of the snorkel faces upwards.
At this point the only fully sealed airbox and snorkel system ( outside of one off custom variants - there are a few on Facebook of all places ) is the one from Rohan at GrenX.
D&G Europe
OEM
I received the custom D&G snorkel, but I haven't opened the box yet. I requested the installation instructions while the snorkel was being made. I plan to fashion a butyl rubber seal for the base of the unit. Will that suffice to seal the RIA, making it a complete snorkel system, or are there additional factors to consider from the snorkel to the airbox, and from there to the engine?
Be careful with oil soaked. Oil getting pulled into the turbo is no bueno.
How well sealed is the airbox? I suppose you could use Sikaflex to seal any seams. The other issue is would be a drain - either a plug ( screw ) or a ball valve for instance.
From looking a the airbox the oval outlet to the intermediate part under the wing looks very hard to seal.
