The perfect Cargo Shelf + Tailgate Table
Shaheens
12:24 AM
Dubai - United Arab Emirates
Hello,
I installed the following items from Bison Gear, the quality is great, very good price and easy to install 👍🏻
- Side table / Tailgate Table (the best part you don’t have to remove the original door cover and worry where to put the first aid kit).
- Roof Shelf / Cargo Shelf
- Folding Cargo (you don’t need it if you have the original fence)
- Under shelf compartment for Front Runners Director chair. (I recommend buying the chairs with the bags so they don’t rattle).
feel free to ask if you need tips for the installation.
Looks great buddy.
Where were the photos taken ?
Hello,
I'm in the market for a drop down table. what made you decide on a Bison? Did you consider GP Factor?
Having the same decision. I like the GP Factor but also like the functionality of having the molle plate on the bottom of the Bison when closed.
Exactly, LabRat. I got bullbars from GP Factor and they are very high quality and were easy to install. So I'm torn. The molle plate on the Bison table is a nice, functional addition.
Based on the photos that I’ve seen, the thing that I don’t like about the GP Factor table is that it blocks/removes access to the existing first aid storage. It would be a contender for me if it had the same ‘border frame’ as the Bison & other similar tables, as the construction and finish of the GPF look good.
Hmmm, that's interesting. I don't have the FAK to go in there and like the molle panel to attach my kit. I have a velcro grab and go and don't want to fumble with opening the storage spot if I really need the FAK in a pinch.
I can see the molle panel being really useful for many, plus the quick-grab access of a velcroed bag, but with my drawer system fitted I don't have the space for items to be fixed to the molle when the door is closed, hence in-door storage helps.
I have a GP table and the Bison shelf. Both are really nice. The GP Factor table has a cubby that your first aid could still fit in. I generally keep a little cookset back there.
For those of you with the Bison table, is your level? Mine has a drop of somewhere between 5-10mm back to front. PITA when I'm cooking as all of the oil or water pools on one side of the pan. Tomatoes and onions roll off the cutting board, etc. I contacted Bison and they've advised it's designed that way to allow water to run off. I haven't seen any others so not sure if this is true or not. I'd much rather have flat and wipe up any water with a rag. It's not like a lot is going to pool on the table anyway. Also, if someone has hacked theirs to level it I'd be interested in how.
Hello,
With the table, what does installation entail? Any drilling or damage to the door, or do screws just go into existing holes?
