(The battery and monitor thread )Car dead in the middle of the woods
das mo
10:33 PM
Hi all.
Car is dead.
Battery was at 50% 2 hours back.
We now packed all together and car does not start.
Is there an Ineos support hotline I can call on a Sunday?
Thanks
Yesterday my two ordered Chinese battery monitoring stuff arrived: each 18.50 euro.
Why I had to allow the "correct location" to be used by the app on my phone is still a mystery for me, only Mao knows.
I only tested the battery voltage, not the other possibilities (cranking test, charging test).
My car didn't move now for nearly two weeks for different non-technical reasons.
This is the picture of my battery status before installing the devices:
Of course, key in, ignition on.
Here some screenshots from my phone, after installing:
I can input myself different names, but the devices are identified by different serial numbers.
The device also saves in it's internal memory the data of a longer period, 35 days according to the app manual.
When you move within the reach of your car this data is synchronized to your phone.
This is the overnight data of the main battery (similar for the auxiliary battery), I didn't open the doors of my car, not one time:
There is also a nice slider to measure voltage peaks or drops at certain moments, first image of the main battery, second of the auxiliary battery, while installing, testing, etc. and opening and closing doors. First image is from the Main Battery, second from the auxiliary battery:
Pïty that on this chart the battery name isn't mentioned!
Evaluation:
  • Device works
  • China is watching me
  • battery voltage quite stable, no sensitive drop in about 24h.
  • state of charge seems to be (in %) the same as what the Grenadier makes of it!
  • Voltage measurement seems to correspond to the Grenadier (see the 12.1 Volt on the info screen, and the 12.13 lowest value of the main battery while installing)
Next steps:
  • crank test
  • charging test (with the device function)
  • drive test
  • some bastards on this forum made me spend more money. I bought a CTEK MXS 5.0 battery charger, arrived today: charge test with the CTEK.
I continue to play around without driving, but I am longing to finally do some travelling again early September, after delaying it three times now!
Upvote 0
I think you may have just paid the favour back. 😖
I love tech like this but probably wouldn't have bought into it without seeing it perform first. Let's see a few more of those tests and providing it doesn't start spewing magic smoke then I might be in...
Upvote 0
View attachment 7824408View attachment 7824407View attachment 7824409
Evaluation:
  • Device works
Next steps:
  • crank test
  • drive test
Thanks Jean - I desperately try to avoid buying Chinese, virtually impossible these days. But looks like I will be spending money on these gadgets. Thanks! 😀
Upvote 0
These battery monitors seem to just measure voltage and thus are very limited in what info it can provide. Is anyone considering a smart shunt like the Victron Energy ip65 500A that can measure voltage,%charge, amp draw and amp charging and plot all the data? This would give a true idea of what is going on with your Aux battery.
Upvote 0
If one in 6 people are Chinese and you have a wife and four children it would make one question whether the child eating cornflakes with chopsticks is kosher.
Upvote 0
Nice toy, but 4 times more expensive than my monitors from Amazon (China?!).
Form my needed knowledge and use, the less than 40€ solution is OK. And if it’s 5-10% wrong, doesn‘t matter, only important that I know before the battery breakdown.
PS: My „Chinese“ is Emax, he got the August files of both batteries, to analyse and report👍🤫
Upvote 0
Evaluation:
  • Device works
Next steps:
  • crank test
  • drive test
They are the same others and me are using.
Upvote 0
OK, I agree, there are more professional solutions, and mine are toys. Doesn't measure amps indeed.
I am playing, I like that.
Your solution is worthfull, professional and costs more money.
Go ahead, once you have your car, post your findings (y)
Upvote 0
I bought one of that model 3 years ago when my old Disco alternator was playing up; played around with it a fair bit and it always seemed to give useful info (not just "voltage"), esp if the car had been sitting for a few weeks and in winter.
It's so transportable you could carry it as a basic diagnostic tool to help someone else out.
Upvote 0
That's what I have been telling since 1871.
But installing a high performance shunt properly is not trivial.
Upvote 0
Upvote 0
Yesterday I continued to play around with the Chinese voltage monitoring devices.
First image: cranking test
According to the manual the test show OK when it is 9.6 Volt or higher.
Second test: charging test, meaning switching everything off that can be switched off (what I didn't do, I left my wireless android auto device in the USB-C port), putting headlights on and playing around with the rotation speed of the motor:
And then I got a phone call, "please can you come to the port of Antwerp?". I said yes. That's almost 90 km one way, one hour drive, mostly motorway, speed mostly between 90km/h and 127 km/h.
Battery at start was about 12.37 Volt "60%". (See the data higher up this thread).
Results (main battery):
  • the first peak around 17h is the cranking test
  • the second peak around 18h: I took gasoline (yes, my tank was empty: I could fill 85.18l)
  • the third long peak is driving to Antwerp (18h15 to 19h15)
  • the fourth is driving back after my assignment (21h30 to 22h30)
In fact, I find everything back in the "trip" screen of my app on my phone:
At midnight my battery voltage was 12.8 Volt:
And today at 18h30 it was still 12.68 Volt:
The Auxiliary battery showed
  • at midnight 12.86 Volt
  • at 18h30 (today, therefore after 18h30) 12.74 Volt
  • a peak while driving at 14.98 Volt
  • the rest of the pattern was quite similar to the main battery.
According to my car infoscreen
  • state of charge was about 60% before going to Antwerp
  • 84% when back home at 22h30 and 12.7 volt with the key in the ignition (motor off)
Upvote 0
Upvote 0
Or you have a very good memory or you use the search function in a very efficient manner.
Actually neither, I had one in my hands the other day. It's a chunky monkey.
Anyway, @Xrford and @Arkaig (and yourself and @emax ) are indeed right to say there are better solutions.
I'm not sure I'm in that camp... the detail you're providing is fantastic & I wonder if anything more is actually required or indeed once initial norms are established and understood, whether there is actually a need to see the data again, until something suggests to you that there may be an issue.
Having said that maybe I need to get a Victron, so there's at least a forum side by side comparison we can run?
Upvote 0
@Jean Mercier I have to clarify that I don't think that such monitors are useless. They give you quite good information. But I want the users to know about the limitations. I'm for example not convinced of the percentage readings as they rely on what the developers have assumed about voltage vs. DoD. But once you've learned to interpret the readings yourself and to be aware of the changes, they can be a good thing.
My "problem" is, that I have some personal requirements for measuring whatever you can measure. But that's just me. :)
Upvote 0
Have you looked at the Victron ones?
No, it's the first time I heard of them. Victron are in general serious products, and I think they are worth a try.
I do however think that the BMW sensor delivers very good data and should in combination with the alreay in the INEOS existing (and hopefully well designed) software be a high end solution. The only missing is the the long-time recording. But over time, some enthusiasts DIY OBD recorder might be able to do that.
Upvote 0
From FB - Aryn Abramowitch:
Added a victron shunt to monitor the AUX battery current and state of charge (no idea why there isn’t a shunt from factory!). The shunt fits perfectly onto the threaded bolts under the seat! It’s like they were put there exactly for this😂
Upvote 0
