Spare Wheel Cover
Might be possible to swap out the lock barrel for one of these?
I did not order the sparewheel box. - Was considering it - but as of now - there might be an aftermarket solution. Perhaps not made from plastic but aluminium or similar.
The idea is great - but what I demand is a little bit different. - I ve got a fried with 3D Printer .. perhaps design a prototype for something that suits my requirements better.
How different? Can you share your thoughts?
Ah, I thought you just wanted to move away from the issue of dust in a normal key lock barrel. 👍
The boxes seem mostly plastic - not metal.
Also it looks like there is no interior shelf or separators. What I dislike if the stuff stored inside is falling around and may be noisy. - Also I like finding and not searching in some bags.
What I also like - is if I had a kind of foldable handle and could after unlocking - the entire box take out and carry it to the place where the equipment inside is needed.
E.g. kind a push to unlock or rotate by a few degrees like a bolt lock, to lock unlock - and then carry the box. - Something like this.
Also the visual presence of a key hole there bugs me - it tells everybody. There is something inside valuable enough that is worth to be locked.
Something like this I had in mind.. Not a simple flap down door molded plastic etc.. .. There I get my problem on value for money. - In all other places Ineos has invested quite a lot of robust capabilities.. but that one just doesn't fit in my opinion.
As with everything there is no one solution that suits all markets and all needs.
In Australia it's a good spot to store recovery ropes, gloves, soft shackles that don't rattle.
And a dirt bag covers the area so thieves aren't tempted.
exactly .. a full cover of spare wheel is something that is a must. Yesterday evening I was out to monitor some grass land that is usually attacked by boar. due to a mixture of rain and snow the area became muddy and wet. The rear of my disco is now rather brown and nicely covered.. so the pressure washer is required.. usual procedure. A covered lock eg by a dirt bag.. is mandatory.
Interesting thoughts, thanks for sharing.
I think someone mentioned something like shadow foam or pick & pluck, if you have a set idea of what you are going to store?
I like the idea of it being removeable. Maybe something similar to the locks for panniers on motorbikes?
That's an excellent grill. But it is only clamped over the wheel.
So you have to secure two items ...
Yes, I know it‘s over the wheel, I‘ d prefer a version which in intergrated in a removable Spare wheel box.
I’ve optioned the lockable spare wheel storage box. But as it will contain probably items I don’t use much, I think I’ll add a spare wheel cover over it to stop UV damage to the tyre
Do you think that dust will manage to get itself between the door and wheels face? If I’m not mistaken, most soft tire covers sort of end just past the width of the rear tire, leaving the side facing the door essentially uncovered. Typically this is the inside of the wheel so it’s not a big deal. However in the case of the IG that would be the face of the wheel. This would be more an issue with the alloys than steelies.
Hm, that doesn't make sense imho.
The cover has a 'closed' surface on the outside. So you can not mount it the other way, i.e. the 'closed' part towards the door.
But may be I didn't get it. :unsure:
No. that’s just showing that the “inside” is not protected. The outward facing side is protected by the cover but the part against the door is not. Thus any dust or debris that can fit between the mount and door itself can collect on the wheel face. Does that make better sense?
Yes, now it's clear.
I think it's common to all the covers that they don't hermetically cover the wheel. My assumption is that mainly the UV-part of sunlight and direct mud shall be blocked.
And in the context of the discussion, it should as well make the locked box invisible.
But dirt on a 4x4 creeping into the gaps of the spare wheel is probably not a shame. ;-)
The other thing I recall with the soft cover on my Discovery rear wheel is that the inner edge where it wrinkled up touched the paintwork in a number of places and ending up rubbing quite bad witness marks through the paint.
Latest posts
