Sound system upgrade and 8-pin connectors disconnect
Thank you very much for the pictures and info. I can attest that the first time removing the plug and plugging it back in is difficult. If you do it a few times it will loosen up. I made two harnesses with the Amazon two sided (male/female) brown harness buy cutting the wires and connecting 9 wire bundles. The 9th wire is a blue remote wire that I did not use. 6 feet each is plenty to run the out and back wires to an amp under my driver’s seat to the head unit and brown plug connected to the speakers.
I went with the Audison SR 4.300 a there is room to spare under the seat. What a difference putting a little power to the speakers makes.
Thanks again for posting the info.
I forgot to update this post - I ended up taking my truck to a specialist to unplug the two connectors. It proved to be impossible for him to to unplug the brown connector too - probably a bad luck situation where mine is pressed in harder. We ended up disconnecting only the gray connector (after disconnecting the batteries of course). That worked well, I was able to connect the tweeters. My sound system and the sound dreading layers I applied made a big difference.
Sound deadening made a huge difference for me as well. Sorry to hear about the connector. I went by feel and accidentally removed the black one first. With it out, it was easier to unplug the brown one for me.
If you go down the Audison route get this
Audison Prima AP 260P&P I/0 ISO Plug & Play Extension Lead In & Out Cable 260cm​
Sorry for not posting sooner, I found it a week ago. Hopefully easier for others going forward.
