- Local time
- 9:53 AM
- Joined
- Mar 9, 2022
- Messages
- 545
Don’t quite get this CTEK system. It seems to be running on BMW software that keeps it from charging normally. If I leave my overhead switch on to power my fridge/cooler and it drains the battery down overnight. Normally not a big deal except the battery doesn’t charge very well the next day. Does a quick charge to 65% or so then goes low amperage so it just trickle charges and doesn’t actually top itself back off. Drive for an hour and it may be at 70% or something. Meaning day two of using the batteries isn’t an option.
-Has anyone found a way to make it charge normally until the battery is full? This doesn’t really help with being off grid for a few days.
-Is there a way to reverse charge through the Dutch plugs? Wondering if I flush mount solar panels to my Leitner rack if they could leave the battery topped off when it sits so I’m not starting the day at 65%. Right now I’m running a charger to the battery through an extension cord I wedge in my door and not thrilled about that.
-If I connect a battery maintainer under the hood to the jump points on the engine block and the positive on the frame will that charge the batteries even with the system off or is that only for jumping with the power on so the electrical system can regulate the current?
