for me, zero. i heard the rock. it was a "shit your pants" so loud when it hit rock. smack on the edge. get the rubber trim.What are the chances that this is just body flex stress
I am a copy-cat too, and I know @Clark Kent was not the first, and I apologize to the first poster of this solution, but I did the same today.I installed the edge protection strip today. To be honest it feels a bit me-too but given how many owners have reported cracks that propagate inwards from a chip near the unprotected edge I'll give this protection strip a crack.
Easy to install. I used less than 3 metres of the 7.9 metres (26ft) in the kit.
My MY23 has the top seal so I only needed to do the sides and bottom edge.
Preparation is important. I used a razor blade scraper to clean the glass. That lifted a surprising amount of gunk off. Then I used Isopropyl alcohol (IPA) to wipe down.
I used a heat gun to soften the molding at the bottom corners. No need for relief cuts.
I had some tape strips ready but didn't use them.
I started at the top left corner and finished at the opposite corner. I used a plastic trim tool to go past the RAI where there is less access to press your fingers onto the molding.
A 30 minute job including preparation.
Amazon USA
Or 2 screensDid the same and had the same costs (in Germany).
Hope it helps, but it also looks good and that is enough reason to install it.
The seal is more than sufficient for 2 cars.
Refresher course on the installation here, thanks to John from Owl Vans. Suppliers also listed.I also just received this rubber edging!
What & where exactly did you buy? I found the originally recommended product on Amazon, bt they would not ship to Germany...Did cost me about 50€, because I didn't find it in Europe and it came from the USA (transport costs + 21% VAT).
You can buy it at Amazon.com in the USA. They charge you and deliver as if bought at their german shop. Takes about 1-2 weeks.What & where exactly did you buy? I found the originally recommended product on Amazon, bt they would not ship to Germany...
The British provider on Amazon doesn't ship to Belgium, therefore probably not to Germany either, but as @WhiteBear said, the American provider does!What & where exactly did you buy? I found the originally recommended product on Amazon, bt they would not ship to Germany...
Ja, top!! Vielen Dank! Werde über Qualität + Verarbeitbarkeit berichten.Wäre dieser Artikel bei Ebay nicht eine Alternative ?View attachment 7909267
I had this on my current window shield and the rock hit in the center. Two windshield lost in the first year. That is $6,000 in glass in one year. I get that it is flat and vertical but so were my jeeps and broncos and I broke 1 of those every few years AND they were maybe $500 to replace. At some point my insurance company is going to drop me.Wäre dieser Artikel bei Ebay nicht eine Alternative ?View attachment 7909267
Tintvent Automotive Door Edge Trim Molding Kit with Tape, L Shaped Lip Guard AU link here, US link here and UK link here
Those things are stupid right? It has to catch the rock precisely to deflect them. If the rock doesn’t make contact with the narrow strip, then it impacts the windshield.Does anyone think a bonnet deflector would deflect stones chips so it flies over the windscreen?
The other brand that has been documented is XYG, a massive Chinese manufacturer. The production marks on the XYG screen indicate it is made to a similar spec to the Pilkington. I wonder what the minimum quantity production run at XYG would be to do a toughened version?Not what I expected, can't remember the name Autoglass guy mentioned to me when he was fitting another vehicle screen.
Apart from O'Briens (who fitted my replacement several months ago with an OEM version), there's also RACQ's windscreen fitting service at Lawnton and Eagle Farm ....might be worth an enquiry.About the replace the original windscreen after about 6 chip repairs and now a crack 3/4 of the way across. I am based in Brisbane Australia. I was hoping to get an XYG replacement (in the hopes it might be more solid that the original Pilkington brand. O'Brien's and National Glass both are saying they cant get hold of any brand aftermarket glass at the moment. Anyone in Brisbane bought one recently and where did you get it from?
