Show us your crack (windshields)
If your windshield cracked (please answer honestly)
  • Diesel : NO evidence of stone chip or damage prior to crack appearing
    Votes: 25 9.2%
  • Diesel : evidence of stone chip or damage prior to crack appearing
    Votes: 33 12.2%
  • Petrol/Gas: NO evidence of stone chip or damage prior to crack appearing
    Votes: 47 17.3%
  • Petrol/Gas : evidence of stone chip or damage prior to crack appearing
    Votes: 71 26.2%
  • No crack
    Votes: 95 35.1%
  • Total voters
    271
I installed the edge protection strip today. To be honest it feels a bit me-too but given how many owners have reported cracks that propagate inwards from a chip near the unprotected edge I'll give this protection strip a crack :cool:.
Easy to install. I used less than 3 metres of the 7.9 metres (26ft) in the kit.
My MY23 has the top seal so I only needed to do the sides and bottom edge.
Preparation is important. I used a razor blade scraper to clean the glass. That lifted a surprising amount of gunk off. Then I used Isopropyl alcohol (IPA) to wipe down.
I used a heat gun to soften the molding at the bottom corners. No need for relief cuts.
I had some tape strips ready but didn't use them.
I started at the top left corner and finished at the opposite corner. I used a plastic trim tool to go past the RAI where there is less access to press your fingers onto the molding.
A 30 minute job including preparation.
Amazon USA
I am a copy-cat too, and I know @Clark Kent was not the first, and I apologize to the first poster of this solution, but I did the same today.
Did cost me about 50€, because I didn't find it in Europe and it came from the USA (transport costs + 21% VAT).
Did the same and had the same costs (in Germany).
Hope it helps, but it also looks good and that is enough reason to install it.
The seal is more than sufficient for 2 cars.
What & where exactly did you buy? I found the originally recommended product on Amazon, bt they would not ship to Germany...
You can buy it at Amazon.com in the USA. They charge you and deliver as if bought at their german shop. Takes about 1-2 weeks.
Search for: tintvent rubber edge trim
Wäre dieser Artikel bei Ebay nicht eine Alternative ?View attachment 7909267
I had this on my current window shield and the rock hit in the center. Two windshield lost in the first year. That is $6,000 in glass in one year. I get that it is flat and vertical but so were my jeeps and broncos and I broke 1 of those every few years AND they were maybe $500 to replace. At some point my insurance company is going to drop me.
Trim suppliers
Here are the known suppliers of the trim (sometimes eBay has suppliers as well):
Tintvent Automotive Door Edge Trim Molding Kit with Tape, L Shaped Lip Guard AU link here, US link here and UK link here
Here is the trim's spec to try and locate other brands. It uses 3M tape for the adhesive strip:
windscreentrim-jpg.7906996
Does anyone think a bonnet deflector would deflect stones chips so it flies over the windscreen?
Those things are stupid right? It has to catch the rock precisely to deflect them. If the rock doesn’t make contact with the narrow strip, then it impacts the windshield.
Not what I expected, can't remember the name Autoglass guy mentioned to me when he was fitting another vehicle screen.
The other brand that has been documented is XYG, a massive Chinese manufacturer. The production marks on the XYG screen indicate it is made to a similar spec to the Pilkington. I wonder what the minimum quantity production run at XYG would be to do a toughened version?
About the replace the original windscreen after about 6 chip repairs and now a crack 3/4 of the way across. I am based in Brisbane Australia. I was hoping to get an XYG replacement (in the hopes it might be more solid that the original Pilkington brand. O'Brien's and National Glass both are saying they cant get hold of any brand aftermarket glass at the moment. Anyone in Brisbane bought one recently and where did you get it from?
Apart from O'Briens (who fitted my replacement several months ago with an OEM version), there's also RACQ's windscreen fitting service at Lawnton and Eagle Farm ....might be worth an enquiry.
Yeah tried RACQ too - they also said they can do OEM only...
I had a stone hit the screen, my problem has been getting a screen, none in the country.
NZ
My word that's a problem. I'm about other move there with my grenadier in January!!!. I'm currently in Australia and about to replace windscreen due to stone chips. I have a choice of original Pilkington that the dealer has in stock which will cost me an excess if replaced under insurance, or the non OEM replacement from o'brines glass which will be covered fully by insurance but is a third party brand - XYG. The XYG some say is better than the original for durability.
I now have over 15,000km on the XYG glass (and also have a rubber surround fitted) and have had multiple rock hits... Several I was almost ducking for cover behind the steering wheel, as I could see the rock flying towards me! Anyhow, loud hits, no chips to date. I am much more impressed with the XYG than the OEM for durability so far.
