Roll Cage for Ineos Grenadier – Built by Safety Devices
If you're serious about off-roading, overlanding, or just want to give your Grenadier the protection it truly deserves, this is for you:
We’re excited to offer a brand-new roll cage engineered specifically for the Ineos Grenadier! The Internal/External Roll Cage is mounted directly to the chassis at 4 locations and to the body at another 4 locations. Full kit comes with Internal B Hoop (available with & without Y bracing), C Hoop and Backstays.
  • Tailored Fit for the Grenadier – No compromises. Designed to integrate perfectly with your vehicle’s structure.
  • Built to Perform – Constructed from high-strength steel tubing, engineered to meet the toughest terrain.
  • Worldwide availability – This roll cage will be available globally through Safety Devices’ network of dealers, ensuring expert support wherever you are located.
  • Roof Rack Compatibility – compatible with Safety Devices' range of Explorer roof racks
Contact us @ expedition@safetydevices.com or comment below for more information.
Very nice, but I can't help but wonder how much of the Grenadier's 700kg payload is used up by the cage.
Nice...
Do you have an approximate weight for the cage?
Hello, thank you for commenting! The tube grades and fixtures are still in the process of being defined but we would say the cage weights appox. 150kg.
Wow, can you talk a bit about the installation and how this is tied into the Grenadier Frame? It looks like it has four (two front, two rear) structural supports and two (mid L track) cosmetic connections. Does it connect through the roof via an internal hoop similar to the Defender 110, and is this capable of supporting the weight of the Grenadier in the event of a rollover?
It looks like there is some provision for a rear hoop? Can you show how it impacts internal space and storage?
If it’d be like the SD cages on the Camel trucks, the truck can be picked up by helicopter by the rack! Flying spanners taken to a whole new level!
