Recall notice
I got the letter for the recall. I never had a problem with sticking door buttons. I’ll probably complete the recall when the parts are available. The thought of a door opening while driving is terrifying.
Same. I thought it was funny that they can't actually fix them yet. My door handles were only sticking over the winter, so as long as they get them fixed by this fall then all good.
Mine were sticking in the cold, but also started sticking again recently. Looking forward to getting that fixed, along with the annoying "Check Engine" I get every time I fill up at a gas pump it doesn't like.
Got the letter in the mail last week. I dont have any issues with my doors sticking but as others have stated when the parts come in I will have them cover this under the recall.
Guessing here, but if your VIN is between CA0 and CA5, you're in the range, and if it includes CA5, and the next letter is lower than R you are in the range. If your next letter is R, go to the next character, F, and rinse and repeat etc.
FWIW, I'm a CA3 and have not yet received the recall notice.
My understanding re VIN is …
SC6 = INEOS Automotive
G = Grenadier
M1 = Wagon
C = Petrol
A = Left Hand Drive
Next digit = Check digit
Next digit = Model year (P = 2023 / R = 2024 / S = 2025)
F = Hambach plant
Last 6 digits = Production number
got mine this week
my buttons were all replaced in january and they have started to stick again
hopefully this recall will be more permanent
Damn… I was hoping my vehicle wasn’t included but I’m within the last 100 VINs on the recall… so close! Frustrating, as I’ve not experienced sticky buttons at all but like others it will probably show up in time. Not really looking forward to having the door cards pulled off as damage, broken retaining clips, torn vapor barriers plus the chances of things going back together as tight and rattle free as they are now seems unlikely. It would be nice if software updates for ADAS, Service Reset, TPMS, etc… would be available at the same time recall work gets done but I’m not holding my breath.
Agree 100%. I won’t be heading in for this recall until January 2026 for my annual warranty
Service.
I took mine in for windshield replacement and all warranty work needed. Have 2,700mi on it after 1 year. Had the 1year service done and waiting to finish up to go get it back. They got the door handle recall parts in and went ahead and did that as well. To bad no software updates to fix the dings clicks and chimes.
Hi all,
I just got a recall notice for the door buttons. It's NHTSA Recall number 25V147 and they are going to replace all exterior door buttons once parts have been received. Anyone else getting this one?
I haven't gotten the notice yet. I did have a problem with the passenger door exterior button sticking. They said they would order the part but after a month it solved itself.
Matt
Picked mine up today from dealer after year service and warranty. Looks like the recall for the doors, requires re-keying the truck. So new key fobs are part of the recall. Said that Ineos couldn't find a way to use the old ones soto just get rid of it and move on. What an expensive waste. Also got about 15-20 windshields in over the weekend. So looks like they are trying to catch up on availability.
Only thing they couldn’t do was the front door seals. I still have the foot bath option till they get those back in stock.
Are the key fobs at least the same style as the originals or are they different? In addition to removing all the door cards they have to monkey around with the dash panels to replace the tumbler mechanism as well… ugh!!!
Yes, the fobs are exactly the same. I was surprised that the fix was as extensive as it was.
Yeah, this level of intrusion, when my buttons work fine, really has me bothered. Based on my “mechanical” dealer discussions, I just don’t want them mucking around under a stopwatch.
my passenger side was replaced a couple months ago, and it stuck 2 days later, so really hope the new parts aren't the same material the old parts, as the cold/water correlation leads me to believe its really a material interface cohesion issue, and not really lube issue at its core.
Best we can hope for is a detail orientated and methodical tech doing the repair but your point about the work being done under at “stopwatch” means these folk are going to be under the gun to work through this recall as quickly as possible due to the number of vehicles impacted. Can’t decide if it’s better to get in sooner, assuming they’ll be more careful taking things apart, or go in much later once they’ve streamlined the process and figured out all the gotchas?
My buttons stuck (3-4 times, rear doors only) about 10-months ago. Never since.
I get it. The parts ought to wear over time and not be an issue, but, now, the vin has a unfulfilled warranty on it if you don't.
warranty issues have a set book time reimbursement. the faster they get with practice, the more they make.
follow da moneeeeeeey.
The dash panels are easily removed to gain access to the tumbler. I had no issues with my door knobs before the recall and I have no issues with the door knobs after the replacement. My key still turns, the grenny still starts, the wheels still go round and round…
