Mine were sticking in the cold, but also started sticking again recently. Looking forward to getting that fixed, along with the annoying "Check Engine" I get every time I fill up at a gas pump it doesn't like.Same. I thought it was funny that they can't actually fix them yet. My door handles were only sticking over the winter, so as long as they get them fixed by this fall then all good.
My understanding re VIN is …Guessing here, but if your VIN is between CA0 and CA5, you're in the range, and if it includes CA5, and the next letter is lower than R you are in the range. If your next letter is R, go to the next character, F, and rinse and repeat etc.
FWIW, I'm a CA3 and have not yet received the recall notice.
Agree 100%. I won’t be heading in for this recall until January 2026 for my annual warrantyDamn… I was hoping my vehicle wasn’t included but I’m within the last 100 VINs on the recall… so close! Frustrating, as I’ve not experienced sticky buttons at all but like others it will probably show up in time. Not really looking forward to having the door cards pulled off as damage, broken retaining clips, torn vapor barriers plus the chances of things going back together as tight and rattle free as they are now seems unlikely. It would be nice if software updates for ADAS, Service Reset, TPMS, etc… would be available at the same time recall work gets done but I’m not holding my breath.
I haven't gotten the notice yet. I did have a problem with the passenger door exterior button sticking. They said they would order the part but after a month it solved itself.Hi all,
I just got a recall notice for the door buttons. It's NHTSA Recall number 25V147 and they are going to replace all exterior door buttons once parts have been received. Anyone else getting this one?
Are the key fobs at least the same style as the originals or are they different? In addition to removing all the door cards they have to monkey around with the dash panels to replace the tumbler mechanism as well… ugh!!!Picked mine up today from dealer after year service and warranty. Looks like the recall for the doors, requires re-keying the truck. So new key fobs are part of the recall. Said that Ineos couldn't find a way to use the old ones soto just get rid of it and move on. What an expensive waste. Also got about 15-20 windshields in over the weekend. So looks like they are trying to catch up on availability.
Only thing they couldn’t do was the front door seals. I still have the foot bath option till they get those back in stock.
Yes, the fobs are exactly the same. I was surprised that the fix was as extensive as it was.Are the key fobs at least the same style as the originals or are they different? In addition to removing all the door cards they have to monkey around with the dash panels to replace the tumbler mechanism as well… ugh!!!
Yeah, this level of intrusion, when my buttons work fine, really has me bothered. Based on my “mechanical” dealer discussions, I just don’t want them mucking around under a stopwatch.Are the key fobs at least the same style as the originals or are they different? In addition to removing all the door cards they have to monkey around with the dash panels to replace the tumbler mechanism as well… ugh!!!
my passenger side was replaced a couple months ago, and it stuck 2 days later, so really hope the new parts aren't the same material the old parts, as the cold/water correlation leads me to believe its really a material interface cohesion issue, and not really lube issue at its core.Yeah, this level of intrusion, when my buttons work fine, really has me bothered. Based on my “mechanical” dealer discussions, I just don’t want them mucking around under a stopwatch.
Best we can hope for is a detail orientated and methodical tech doing the repair but your point about the work being done under at “stopwatch” means these folk are going to be under the gun to work through this recall as quickly as possible due to the number of vehicles impacted. Can’t decide if it’s better to get in sooner, assuming they’ll be more careful taking things apart, or go in much later once they’ve streamlined the process and figured out all the gotchas?Yeah, this level of intrusion, when my buttons work fine, really has me bothered. Based on my “mechanical” dealer discussions, I just don’t want them mucking around under a stopwatch.
I get it. The parts ought to wear over time and not be an issue, but, now, the vin has a unfulfilled warranty on it if you don't.My buttons stuck (3-4 times, rear doors only) about 10-months ago. Never since.
warranty issues have a set book time reimbursement. the faster they get with practice, the more they make.Best we can hope for is a detail orientated and methodical tech doing the repair but your point about the work being done under at “stopwatch” means these folk are going to be under the gun to work through this recall as quickly as possible due to the number of vehicles impacted. Can’t decide if it’s better to get in sooner, assuming they’ll be more careful taking things apart, or go in much later once they’ve streamlined the process and figured out all the gotchas?
The dash panels are easily removed to gain access to the tumbler. I had no issues with my door knobs before the recall and I have no issues with the door knobs after the replacement. My key still turns, the grenny still starts, the wheels still go round and round…Are the key fobs at least the same style as the originals or are they different? In addition to removing all the door cards they have to monkey around with the dash panels to replace the tumbler mechanism as well… ugh!!!
