Quartermaster Flatbed/Canopy Power Setup – Sanity Check
AFdude412
11:22 PM
Colorado, USA
Hey all,
I’m getting a Dirtbox flatbed + canopy camper installed on my Quartermaster soon and have been working through power setup options. Figured I’d throw this out here to sanity check my plan and see what others are running.
For context, I also have a Grenadier wagon running a Redarc BCDC Alpha 50, 150Ah battery, and Garmin Power Switch. It’s been a really solid setup and I’ve been happy with it overall.
My initial thought was to replicate something similar in the Quartermaster, but with the canopy setup I’m not sure if that’s the best approach.
Current idea:
  • Keep the factory dual battery system up front
  • Run a Redarc BCDC Alpha 50 to the canopy
  • 200Ah lithium house battery in the canopy
  • Garmin Power Switch for accessory control
  • Redarc 2000W inverter for onboard power
Main question:
Does anyone see any issues with this layout, particularly keeping the stock dual battery system while feeding a separate lithium house system via the BCDC?
Also open to suggestions if there’s a better way to approach this with a canopy camper setup.
Photos for reference below—current QM, existing Redarc setup in my wagon, and the planned canopy layout.
Appreciate any input!
Hey all,
Current idea:
Main question:
View attachment 7924602View attachment 7924603View attachment 7924604
I run something similar, but removed my second battery as its 30+ kgs of dead weight IMO.
I have the Redarc Core 40 dcdc charger in the canopy as it's recommended to have the charger as close to the battery as possible.
I also have a 200 ah lithium. Switching is done via Bluetooth switch panel to keep things clean. 115lt upright fridge, powering devices and will have a 3000w inverter for induction cooking.
I never had the dual battery set up in my QM. Went with slimline battery with Redarc 40amp DC to DC. The Dirtbox comes with switches already installed but I like your idea of power switches.
That’s a solid setup. I’ve definitely thought about pulling the second battery too—mainly just to simplify things and not carry the extra weight. I also thought about making the same setup as my Grenadier's Redarc setup, but it would be too difficult to get the wiring to the canopy.
I think where I’m getting hung up is how to best lay it out with the canopy. Makes sense what you’re saying about keeping the charger close to the lithium.
Might be overthinking it, but trying to get it right the first time. Appreciate the input!
Hey all,
Current idea:
Main question:
Curious, What rear springs will/are you running in the build? Eibach 1,000lb?
I ran one of feed from the start battery through the floor, there is a hole that is suitable on the drivers side (passenger for LHD) , one cable gland penetration through the wall on the passenger side. Made a head board for the charger and associated wiring.
I have a 40lt water tank under my service body/tray. Slide out drawer which is handy and negates the need for a table, added a water pump to the tank rather than have it gravity fed.
