Oil Drip
4x4Brick #1561
11:05 PM
My wife noticed spots on the drive way and I started looking and it WAS the Grenny! Took a look and it seems to be coming from the oil sump plug. Good because it should be an easy fit. BUT... I took some pictures and sent them to my dealer Mossy Houston but of course Murpy's Law says you find drip after service hours. So I'm poling the forum. I'm o.k. double checking the bolt tightens to 25Nm thanks to Rok Dr as always. I wasn't getting a low oil warning but after I checked the level (first time doing that) it came back with a 'WARNING - LOW OIL LEVEL' and a add recommendation. Hence the but. This says 1.0l which I'm assuming is liter. I watched the oil change video recommendation (again all hail Rok Dr) and noticed the youtube guy also got and exact 1.0l (and he said liter) notice. How precise is this electronic measurement? Will it actually give an add amount that is not a round number is needed or is the generic add amount always 1.0l? And I wonder why I didn't get a low oil notice until I measured it. Any advice welcomed.
If itcreally only the oil plug smear some Hylomar on the first threads, next time. You can screw it in while oil wet.
Sealed.
AWo
@4x4Brick #1561 I believe full ( for offroad) is 7.5 L. I've just had a 7L fill and get the add 500ml message.
As for this table, not sure where that is!
That’s leaking too much to be normal after a service. A good tech will wipe down the pan / nut if it’s got some drips on it.
Maybe they forgot to put on a new crush washer on the drain plug. Definitely check torque on the drain plug.
